- Thank you received: 8
inter Diamond motor hot box gasket
7 years 10 months ago #169709
by wombat 46
inter Diamond motor hot box gasket was created by wombat 46
7 years 10 months ago #169735
by 600Dodge
Replied by 600Dodge on topic inter Diamond motor hot box gasket
You might struggle to buy one but if you are going to make one try the aluminium backed gasket material the same as exhaust gaskets are made of or some annealed copper sheet if you can find some.
7 years 10 months ago #169745
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic inter Diamond motor hot box gasket
Send the old gasket to a gasket manufacturer, like Swanson's Gaskets in Sydney, and they will make a new one to match it.
We have been using Swanson's for a number of years and have had excellent service from them. They specialise in old vehicle stuff.
7 years 10 months ago #169752
by Hommie1973
Replied by Hommie1973 on topic inter Diamond motor hot box gasket
Hi Wombat, Try Supercheap they may have what you want it is heat proof black looking sheeting that you can cut to the shape you require. It is around $12 from memory, I used it to make a gasget between my manifold and the exhaust 4 bolt joint on my Commer. It can be cut useing tin snips to shape it to your requirements.
