- Thank you received: 12
Perkins Phaser 180ti tacho drive
- Kwakatriple
Can anyone tell me where the tacho drive should be on the 180 and perhaps even give me a pic of what it looks like?
Thanks in advance
1964 Bedford bus/motorhome
1972 Bedford bus/motorhome
...and sundry other 2, 3 and 4 wheel vehicles...
Maybe electrical off the back of the alternator?Kwakatriple wrote: So I am putting a Perkins Phaser 180ti into my 1964 Bedford bus but there is no obvious tacho drive on the motor. I pulled the cover off that exposes the end of the injector pump drive thinking I would swap the drive off the old 6354 but discovered it is all different and it turns in the opposite direction so that is clearly not going to work.
Thanks in advance
manual : docs.google.com/document/d/1wFngKVZAkvXs...WN95ndqThBWV5IM/edit
about $150 on ebay
- Thank you received: 49
- Kwakatriple
- Thank you received: 22
I'd like to fit all the gauges with the chrome rings and the scale etched onto the back of the lens... but perhaps I'll have to canibalise the electric movement and put it into the mechanical case...? Electric ones are simpler of course...
- Kwakatriple
- Kwakatriple
- Thank you received: 4630
seeya
