Steel Hydraulic brake pipe
- Hommie1973
7 years 7 months ago #173763
by Hommie1973
Steel Hydraulic brake pipe was created by Hommie1973
Hi, Just seen some Copper Nickel brake pipe for sale and was wondering if this type of pipe is ok to use on a truck. I am needing some 30 feet of 5/16 to redo the brakes on my 51 Commer R7. On other projects I have always used steel bundy pipe but if this other stuff is better I will go with it. If anybody has used it and found it ok I would like to hear about it. The seller told me that it is used on trailers but could not tell me if it was ok for what I wanted to use it for. Any help much appreciated Graham
7 years 7 months ago #173766
Replied by mammoth on topic Steel Hydraulic brake pipe
Probably better than bundy because it won't rust and easier to bend. Must not be allowed to vibrate as will be prone to work hardening and then stress cracking. Rare to see any tube these days in larger sizes. As it will have thick wall be careful about sizing. ie is old mate quoting external diameter instead of internal which is what counts.
Having said that get the final word from an expert on brake specs.
- Hommie1973
7 years 7 months ago #173797
by Hommie1973
Replied by Hommie1973 on topic Steel Hydraulic brake pipe
Hi Thankyou for the info apparently it is now the go useing this Copper Nickel pipe. I had a look on u tube and there was some items showing that it is used widely in the brake repair business so I will go with it. Thankyou Mamoth for your input on this matter much appreciated.. Graham
7 years 7 months ago - 7 years 7 months ago #173803
Replied by jon_d on topic Steel Hydraulic brake pipe
Best to give a brake joint a ring, certain materials can't be used.
If you look at ADR 42 or VSB6 (modification for heavy vehicles)
It might say the following;
Air Brake Piping should be manufactured to SAE J844 or equivalent.
• Air Brake Hoses should be manufactured to SAE J1402 or equivalent.
• Hydraulic Brake Piping should be manufactured to SAE J1047 or equivalent.
• Hydraulic Brake Hoses should be manufactured to SAE J1401 or equivalent.
• Flares for Tubing should be in accordance with SAE J5336 or equivalent.
Does the copper nickel pipe comply to SAE J1401?
Last edit: 7 years 7 months ago by jon_d. Reason: update
- Thank you received: 49
7 years 7 months ago #173940
by wedgetail84
Replied by wedgetail84 on topic Steel Hydraulic brake pipe
copper nickel seems to be the go. Better than steel in every way I think I remember finding after research? Longer lasting, easier to form, very almost as strong when new, much stronger after a year or too...
Time to create page: 0.426 seconds
