Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: plumbing diagram for pbr 4 trailer brake
plumbing diagram for pbr 4 trailer brake 31 Mar 2013 19:35 #112207
  • v8 inter nut
  • v8 inter nut's Avatar
Anyone tell me where to put the air lines to this hand controler I think I have it right but not sure
The administrator has disabled public write access.
Re: plumbing diagram for pbr 4 trailer brake 31 Mar 2013 20:08 #112208
  • Buc
  • Buc's Avatar
V8,
Try and search the 4M as I remembers there was some diagrams posted some time back cos I be pinch'm fer my records. :P
Here be one link fer ya ta check out but I be sure there be othas. ;)
www.hcvc.com.au/forum/YaBB.pl?num=1287914367/2#2
Regards, Buc. :)
Re: plumbing diagram for pbr 4 trailer brake 31 Mar 2013 20:30 #112209
  • hayseed
  • hayseed's Avatar
  • Thank you received: 81
V8, as buc says..
there have been a couple of threads 'bout this. but I cant' find 'em...
I think IHscout may have started one, ...........
Re: plumbing diagram for pbr 4 trailer brake 31 Mar 2013 20:50 #112210
  • bigcam
  • bigcam's Avatar
  • Thank you received: 1
I can tell you where they go but you'll have to wait until I'm back at work to look at a valve.
The valve is marked pretty well anyway.
From memory, the air goes into the hole closest to the steering colomn, the emergency or constant trailer supply is the hole at the other end of the valve, directly under the tractor protection valve, the control line which is the blue line to the trailer is one of the middle ones, then you have an exhaust and the one from the treadle valve as well.
If you take a photo of the underside of the valve showing the markings I can tell you which air line goes where.
Re: plumbing diagram for pbr 4 trailer brake 31 Mar 2013 21:03 #112211
  • v8 inter nut
Thanks cam would it be okay if I could ring you tomorrow when I'm infront of it as I would like to get it sorted. Pm me your number if that is okay
Re: plumbing diagram for pbr 4 trailer brake 31 Mar 2013 22:44 #112212
  • jimbo51
  • jimbo51's Avatar
  • Thank you received: 5
This might be of some use.....
Re: plumbing diagram for pbr 4 trailer brake 01 Apr 2013 09:24 #112213
  • IHScout
  • IHScout's Avatar
  • Thank you received: 3
Hi V8 Inter, you've probably got all the info you need with Jimbo's post, but the ither topic referred to by Hayseed n Buc is here http://www.hcvc.com.au/forum/YaBB.pl?num=1327918313/0
Dennis
Re: plumbing diagram for pbr 4 trailer brake 01 Apr 2013 13:45 #112214
  • 600Dodge
  • 600Dodge's Avatar
So in this set up what releases the spring brakes? Is it the tpv end of the CA300? or do you need another valve? My Dodge has air over brakes and a full mechanical handbrake so it doesn't have air park brake valving.
Re: plumbing diagram for pbr 4 trailer brake 01 Apr 2013 13:53 #112215
  • Swishy's Avatar
  • Thank you received: 70
Tiz a proportion n valve to trailer brakes
th@ iz mainly controlled from truck brake pedal
U can dial up how much the brakes on trailer work
(Subbies luvd these valves to wear out bosses trailer brakes n preserve his own truck brakes)
also dependin on the load ratio truck - trailer jist dial for abalanced brake n system
Re: plumbing diagram for pbr 4 trailer brake 01 Apr 2013 14:30 #112216
  • jimbo51
  • jimbo51's Avatar
If you are talking about spring brakes on the prime mover it would be a separate valve and circuit.
The CA300 pre-dates the introduction of spring brakes on trailers but I don't see any reason why it wouldn't work via the tractor protection valve with the appropriate spring brake control and relay valves on the trailer.
  • Page:
  • 1
  • 2
Time to create page: 0.403 seconds
Powered by Kunena Forum
