- Thank you received: 872
Fire Trucks
8 years 7 months ago #133895
by overnite
Replied by overnite on topic Re: Fire Trucks
I wouldn't crank any motor for 30 seconds, unless I had shares in a starter motor company.
8 years 7 months ago #133896
by Bugly
Replied by Bugly on topic Re: Fire Trucks
Looks like I gave my handbook away with the truck. I don't remember there being a 'cold start' trick though. Two good sized 12V batteries cabled in parallel gives plenty of oomph for starting. Cheers - BuglyI'll have a look in my Merc handbook. I think I've still got it, unless I left it in the truck when I sold it. I never had problems starting, but then our ambient temperature in WINTER is about 28 degrees!!
8 years 7 months ago #133897
by iank
Replied by iank on topic Re: Fire Trucks
Many thanks for checking for your book Bugly. I do (now) agree that there is no cold start procedure. I also agree that 2 well charged parallel wired big batteries certainly improves the starting - as I have proved over the past couple of days.
Thanks again, iank
Thanks again, iank
8 years 7 months ago #133898
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: Fire Trucks
We've got a Merc and a couple of Iveco with Deutz donks. The need a lot of cranking over to get started if left too long. Just seems like the fuel is draining back into the tank from the lines. Thinking about putting a NR valve into the line.
8 years 7 months ago #133899
by iank
Hi Beaver, You may be right there with the fuel bleed back. This truck of mine has a 4 cyl Hatz diesel on the back driving the fire water pump. At first I had to crank for "too" long to start it and found myself hand-priming it before it would kick for exactly the same reason. I have cured that beautifully by fitting a little electric in-line fuel pump right at the engine, which runs when I turn the "ignition" on, then cuts out when the engine starts (ie alternator starts to provide output voltage).
iank
iank
- Thank you received: 307
8 years 8 hours ago #169414
by Roderick Smith
Replied by Roderick Smith on topic Fire Trucks
See also this modern one in a different part of the forum:
www.hcvc.com.au/forum/modtruck/15445-epp...vic-fire-truck-named
Roderick
Roderick
7 years 11 months ago #169809
by Roderick Smith
Replied by Roderick Smith on topic FSMV open day, Sat.7.5.16
Vintage fire engines on display for MFB’s 125th anniversary.
May 3, 2016 Hobsons Bay Leader.
Fire Services Museum president Mike McCumisky preparing the vintage fire trucks for display. Picture: Mark Wilson.
THE days of the horse-drawn fire cart are long gone, but with the Metropolitan Fire Brigade celebrating 125 years of serving Melbourne, it’s time to dust off the vintage trucks for a special display.
The Fire Services Museum of Victoria will open the doors of its Newport workshops from 10am to 4pm this Saturday, May 7, to exhibit dozens of lovingly-preserved fire appliances from the past 100 years.
Maintained by volunteers and retired firefighters, the workshops, opposite Williamstown Cemetery in Champion Rd, provide a unique insight into the evolving technology used by Victorian firefighters to keep the community safe.
In its first year, MFB had 59 permanent firefighters, 229 auxiliary firefighters, four steam fire engines, 25 horse drawn hose carts and 58 hose reels. There were only 33 horses and 48 stations in 1891, and the brigade attended 816 calls and 485 fires, of which 188 fires were classified as serious.
Since then it has grown to a workforce with more than 2200 employees, 47 fire stations and 147 fire and specialist appliances. In 2014-15 MFB attended 36,923 calls.
As part of MFB’s 125th Anniversary Celebrations, the public can get up close to the old fire trucks and talk to retired firefighters about their time in the service.
The event will include a barbecue and photo opportunities.
Entry is by gold coin donation.
< www.heraldsun.com.au/leader/west/vintage...1e410ea8fe9aa868f394 >
7 years 11 months ago - 7 years 11 months ago #169818
by Beaver
Replied by Beaver on topic Fire Trucks
Last edit: 7 years 11 months ago by Beaver.
The following user(s) said Thank You: AB120, Roderick Smith
7 years 11 months ago #169819
by atkipete
Replied by atkipete on topic FSMV open day, Sat.7.5.16
Will get along for that.
7 years 10 months ago #171039
by eerfree
Bob,
I do not know how I got over the hill without ever getting to the top.
Replied by eerfree on topic Fire Trucks
Bob,
The following user(s) said Thank You: Roderick Smith, HARDSHAR
Time to create page: 0.551 seconds
