- Thank you received: 402
Please help with IH 766 Information
8 years 2 months ago #166754
by Urchy87
Adventure before Dementia.
Replied by Urchy87 on topic Re: Please help with IH 766 Information
So I've finally got something to tow around. Will be collecting a TX Gyral in a week or so. Things are finally starting to happen.
My next question is regarding the Torque Amplifier. In which position (pushed forward or pulled back is it 'OFF'). No one I've spoken to is too sure as it's been years since they owned one and the guy I purchased it from wasn't even sure himself so left it where it was when he got the machine second hand.
Urchy87
Urchy87
- Thank you received: 4707
8 years 2 months ago #166767
Replied by Mrsmackpaul on topic Re: Please help with IH 766 Information
its on in both positions if that makes any sense whether its up or down its pump oil to the clutch pack
high is a direct drive and low is going thru the gears of the TA
8 years 2 months ago #166768
Replied by hayseed on topic Re: Please help with IH 766 Information
You'll be better off leaving It in High. As they usually stop working in Low First..
8 years 2 months ago #166769
as Hayseed said most are removed or disconnected as they werent the most reliable thing out there
8 years 2 months ago #166792
by Urchy87
Ok. Thanks guys. Makes senses that it is always operational as the seal in the shaft was leaking in both positions when I was trying to figure out when it was and wasn't operational. So is high pushed forward or pulled back? Thanks again.
8 years 2 months ago #166803
by dieseldog
Replied by dieseldog on topic Please help with IH 766 Information
Urchy mate, just give it a try. One position will speed it up and the other will slow it down. Most hi/lo setups are designed to run in high and are only shifted to low when you need the torque. Don't worry about hurting anything, just keep the oil clean, the filters new and don't use low to slow the tractor down on the road and she'll be right.
8 years 2 months ago #166863
by ozfarm
Replied by ozfarm on topic Please help with IH 766 Information
forward is hi
back is low
they where designed to be an under gear, work in high, use low to get thru the tough spots
i replaced the ta in my 886B after 7000hrs was replaced due to the input shaft chewing out, not the ta failing
back is low
8 years 2 months ago #166870
by Urchy87
Replied by Urchy87 on topic Please help with IH 766 Information
Thanks guys. Stand by for more questions as I progress with things.
8 years 2 months ago #166964
Replied by Sarge on topic Please help with IH 766 Information
and where are the photos of these wonderful toys????
Time to create page: 0.545 seconds
