- Thank you received: 51
Fargo 6 volt to 12 volt starter.
8 years 1 month ago #166905
by geoffa
Fargo 6 volt to 12 volt starter. was created by geoffa
I have a 1938 Fargo truck with a 6 volt foot pedal mechanically engaged starter motor. I would like to change it to a 12 volt solenoid operated type starter motor. Has anyone done a conversion such as this ?.
I understand Chrysler changed to 12 volt systems in the mid 1950's and that the side valve 6 cylinder engine was fitted in some of their vehicles until about 1960 so would a starter motor from one of these later cars and trucks fit the older engine ?.
The engine number in my Fargo is T41 27334 and it is a 25 inch long engine.
Geoff.
Geoff.
8 years 1 month ago #166906
Replied by asw120 on topic Fargo 6 volt to 12 volt starter.
A mate had an AP3 Wayfarer (with the 250 - 6) for a while, about 10 - 12 years ago. I had to rebuild the starter, it was a standard 12 volt Lucas M45(?) IIRC. It ended up with either the fields, or armature from an AR110 6 volt starter in it. I'd think any Chrysler Royal, dodge Kingsway, dodge 108, starter should go in.
8 years 1 month ago #166962
Replied by Sarge on topic Fargo 6 volt to 12 volt starter.
geoffa, if it is anything like the 6 volt starter in the O series beddie I recently parted with, it is quite happy to run on 12 volt. It was a mechanical (cable) starter.
- Thank you received: 22
8 years 1 month ago #167143
by invested energy
Replied by invested energy on topic Fargo 6 volt to 12 volt starter.
Many 6 volt starters will handle 12 volts, what doesn't hang together is the drive/pinion/bendix mechanism. Something that's pre-engaged, with a solenoid or a lever or something to force the gears into mesh before applying full torque will cope much better than a crash or inertia drive.
Some use a resistor of some sort to drop the voltage, but this only works under load and so the violence of engagement isn't softened at all.
8 years 1 month ago #167415
by ARmad90
Replied by ARmad90 on topic Fargo 6 volt to 12 volt starter.
if its mechanically engaged starter meaning a series of rods push the drive assembly into mesh once reaching the correct position the switch activates the solenoid there shouldn't be many issues with using the original 6 volt starter should be fine, many 6 volt starters are heavily over built for there application and handle the extra voltage no issue, seeing as the main issue is resistance and current flow through the fields upping the voltage tends to lower the resistance minimising the current needed to start the vehicle, i know from personal experience the fj holdens back in the day when the local battery shop could make battery's the made custom 8 volt battery's for them and just adjusted the charge system to suit but now is common practice to now simply modify the vehicle to 12 volt, if you have any real trust issues in your starter get an old school auto sparky to check it out for you they should soon be able to tell you , not many guys my age got the kinda old school rebuild education i got as an apprentice i would be happy to check it out for you but its a touch hard stuck down here in TASSIE
Time to create page: 0.437 seconds
