- Thank you received: 4
tire pressure
What's the brand of the tyre? A quick google of brand and size might give you the info you need.
Colin
- Thank you received: 4694
Limited Access Excavations.
- Thank you received: 22
Low tyre pressures are only good for sand...
75psi would be good.
trucksyd wrote: I didn't know that , although when I went to pump the tyres up with the digital pump at the servo I set it to around 45 psi, so the pump released air ,so obviously it had 50lb ,or so already in it. They were new front tyres , & this is my first truck , I've had trouble with cars in the past , & I won't go over 38lb , in my car as I've put 40lb in them & they blow out on a hot day.
A word of advice- don't ever rely on a tyre pressure gauge at a servo. I seriously doubt that any of them would be calibrated in their life time. I have seen so many that are so far out and even some digital ones that won't even give the same reading on the same tyre 10 seconds later. Invest in an $8 stick type pressure gauge and you'll never go wrong.
