- Thank you received: 8
Restoration of 1937 ME31 30 cwt Dodge.
7 years 5 months ago #175483
by wombat 46
Replied by wombat 46 on topic Restoration of 1937 ME31 30 cwt Dodge.
looking really great
thanks for sharing
Jim
thanks for sharing
Jim
7 years 5 months ago #175825
by geoffa
Replied by geoffa on topic Restoration of 1937 ME31 30 cwt Dodge.
7 years 5 months ago #175836
Replied by asw120 on topic Restoration of 1937 ME31 30 cwt Dodge.
May I ask how you got the centres out? I have tried this recently, to no avail. After drilling all the rivets out, cannot move it 1 mm. It seems the rim is also shrunk on.
Thanks in advance,
Thanks in advance,
- Thank you received: 4697
7 years 5 months ago - 7 years 5 months ago #175838
Replied by Mrsmackpaul on topic Restoration of 1937 ME31 30 cwt Dodge.
well the ones I have dont just drop out I did a rim only few nights ago block of wood and a big hammer they come out
then clean them up real good and hammer them with the block of wood into where they need to be
Then I bolt them back up and put a dial indicator which I think is over kill and use a porta to gently shift it till its running straight
I then tack weld them then check the run out again and fully weld them back in
I think they heat the rims in the factory to grow them a bit then just drop the centers in
Last edit: 7 years 5 months ago by Mrsmackpaul.
7 years 5 months ago #175839
Thanks Paul. I tried flogging them with an FBH without result. (Inter 120 6 stud singles)
Was going to try tractor bucket next, with besser brick under the centre. I have some with good centres and some with good rims.
I don't think the dial indicator is out there, although I just use a rod clamped to a screw jack and watch for a gap (damn Inter shimmy) at the rim edge and tyre.
I must have another go.
7 years 5 months ago #175857
by geoffa
Firstly we tried drilling a 3 mm hole through the rivet and driving it inwards. It worked but was hard going, we now grind off the rivet heads and drive them outwards quite easily. This works well and we now believe the rivets are tapered. We are able to knock the centre out with hammer in the photo.
Geoff.
Geoff.
7 years 5 months ago #175858
by geoffa
7 years 5 months ago #175879
Thanks for that. I must just be weak, or something!
Cheers, Jarrod.
geoffa wrote: Firstly we tried drilling a 3 mm hole through the rivet and driving it inwards. It worked but was hard going, we now grind off the rivet heads and drive them outwards quite easily. This works well and we now believe the rivets are tapered. We are able to knock the centre out with hammer in the photo.
Geoff.
Cheers, Jarrod.
7 years 5 months ago #175885
Jarrod I dont have a press or anything flash like that but I find with Trewhella jacks and porta powers etc and big trees and big lumps of machinery if I can put lot of force on what ever it is I am trying to shift if it still wont budge I push as hard I can with the jack then hit it as hard as I can with a big hammer almost all things come apart
I think the jacks take the spring out of it so the force of the hammer is a lot greater dunno if thats true or not but it seems to work for me
And some rims I have done take a lot of hammering just to get them to move
7 years 3 months ago - 7 years 3 months ago #177389
by geoffa
Last edit: 7 years 3 months ago by geoffa.
Time to create page: 0.534 seconds
