What timber to use on a 1927 chev truck cab and tray
- cranky crank
7 years 10 months ago #170589
by cranky crank
What timber to use on a 1927 chev truck cab and tray was created by cranky crank
Hi,
I am about to start building the wood cab and tray on my 1927 chev truck.It is a full wood cab with no metal panels and a wood tray.I have found the style of cab I want to build with all the dimensions copied from a restored truck but I am unsure what timber to use.
My selection found at the building supplies shop is kiln dried ash or pine.The pine is the good pine/non treated stuff and about half the cost but I am still favoring the kda.
Not to sure about plywood for some of the cab parts as I intend to round the edges and shape them and the ply grain will be obvious on the edges,and not to sure how it would stand up to a router when cutting the slots in for the glass and then holding the outer beading that holds the glass in place.
What timber have you used ,its strength,ease of fabrication and long term durability?.
Anyone got some pictures on what they have done and used on their vintage trucks?
Cranky crank
Cranky crank
7 years 10 months ago #170603
Replied by Morris on topic What timber to use on a 1927 chev truck cab and tray
I am told that any kiln dried hardwood is the way to go. Ash is preferred by many.
Plywood was not used in the day but VERY wide ((by today's standards) boards were available. They did not appear to warp, maybe they were kiln dried or had been well aged before cutting.
7 years 10 months ago #170846
by wombat 46
Replied by wombat 46 on topic What timber to use on a 1927 chev truck cab and tray
I think this is a real good question,
i would not skimp on the timber.
The first step would be if it is going to be painted or stained and laquered?
Then look for some Aussie made timber where you have some prior tech advise and warrantee
Most off the shelf timbers are imported and the seller has no clue what the species or glue used in the plys
Keep us posted what you find out.
Jim
Jim
7 years 10 months ago - 7 years 10 months ago #170850
Replied by Lang on topic What timber to use on a 1927 chev truck cab and tray
We built the body on a 1915 Willys Overland completely out of ply (all modern quality ply meets the waterproof glue specs of the old marine ply so you can be pretty sure it will do the job).
We took her 6,000km around QLD on lots of dirt roads in all sorts of weather and had no cracking of the acrylic paint and certainly no edge grain splitting. Wood is great stuff to work with and if you use the good glues, backed up by screws in strategic spots, you will have no problems.
Last edit: 7 years 10 months ago by Lang.
- cranky crank
7 years 10 months ago - 7 years 10 months ago #170855
by cranky crank
Replied by cranky crank on topic What timber to use on a 1927 chev truck cab and tray
Hi,
I have had a look at a few chev truck restorations and have decided on using the kiln dried ash as the wood has more of an authentic look than using flat slabs of ply.
I have measured a few trucks and have started making the tray.
Last edit: 7 years 10 months ago by cranky crank. Reason: spelling
- Neil Skulander
2 years 10 months ago #222748
by Neil Skulander
Replied by Neil Skulander on topic Additional info about "Desotodav" post 27th May 2016 What timber to use ----
The 1929 Chevrolet Truck that's pictured ( S11951 ) restoration was initially started by Ken Franks up here in Sydney . I built the cab & tray to fit through his garage door . Tasmanian Oak is used throughout. I have a couple of before & during photos if he's interested. Cheers. Neil.
2 years 9 months ago #222926
Replied by cobbadog on topic Additional info about "Desotodav" post 27th May 2016 What timber to use ----
We are always interested in seeing pics of restorations and repairs.
2 years 9 months ago #222934
Replied by Morris on topic Additional info about "Desotodav" post 27th May 2016 What timber to use ----
Neil Put the pics up here please, we are always interested in before, during and after.
Your name sounds familiar, were you on the 10th Anniversary run of the VVCCA to Mudgee back in 1978? I was in the dark blue 1929 Ute from Melbourne.
Time to create page: 0.529 seconds
