- Thank you received: 40
Air Brakes
7 years 8 months ago #172920
by 67mustang
Air Brakes was created by 67mustang
7 years 8 months ago #172958
Replied by Swishy on topic Air Brakes
67 Must Hang
th@ control hand piece would work but make hard work try n to use a hand allowing for time deley on n off
the yanks have a factory preset trailer control valve th@ applies Truck 60% trailer 40%
U can get a way with A PBR CA300 (not sure if they still legal or not)
but U can dial up the ratio of truck/trailer
Clikity ............................................... ClikClikClik
Happy Brake n
Happy Brake n
7 years 8 months ago #172959
by 67mustang
Replied by 67mustang on topic Air Brakes
Thanks Swishy
Will have a play next weekend, do the wife thing this weekend, a few brownie points.
hopefully we can sort it out, otherwise will be back with a few more brake photos for options.
67mustangs
67mustangs
- Thank you received: 49
7 years 8 months ago #172960
by wedgetail84
Replied by wedgetail84 on topic Air Brakes
why does stang's hand piece create a time lag?
7 years 8 months ago #172961
Replied by bigcam on topic Air Brakes
If it's working leave it alone.
The CA 300 will replace it no worries if it is crook.
Swishy, they aren't illegal, you can still buy reco ones.
It is just illegal to fit them to new trucks because the driver can adjust the truck/trailer brake ratio.
But anything that was fitted with them up to about 20 years ago is fine.
7 years 8 months ago #172964
Replied by Lang on topic Air Brakes
I would leave it alone if it is working. I can recall they do have advantages in being able to put the trailer brakes on to straighten everything out without touching the truck brakes if things are getting a bit sideways on a wet road. You might need a third hand sometimes trying to change down and apply the trailer brakes at the same time if you have not organised yourself properly. I don't know about you other blokes but I found using the handpiece as a part of normal braking with just the right amount of pull became second nature and required no active separate thought.
7 years 8 months ago #172965
Wedgy
M80
Very hard to contol brake n .............. with a hand piece
as there is no feel
probly more to do with wot U use to
where by the foot pedal can react more precisely 2 your needs
M80
as there is no feel
7 years 8 months ago - 7 years 8 months ago #173044
by Maxidyne
Replied by Maxidyne on topic Air Brakes
I personally think the CA300 is a great device, but it does require some additional input and some drivers unfortunately don't get that in affect, you have a brake bias valve that requires attention to suit the conditions and load best.
As Previously mentioned basically from ADR38 onwards the trailer bias became fixed and then with the introduction of ABS, it's done for you. I agree, that nothing gives better feel than a quality foot valve. A hand piece simply can't offer that, or be modulated as well.
It's simply a matter of what works best for the individual operator...
I'm pretty sure Protex offers them as a new component in their extensive retro range of brake products.
Last edit: 7 years 8 months ago by Maxidyne.
Time to create page: 0.583 seconds
