- Thank you received: 66
Hoo U Gunna Call
7 years 5 months ago #175681
by defective
Replied by defective on topic Hoo U Gunna Call
Swishy found a new vocation....put Krueger outta work !!
7 years 5 months ago #175708
Replied by Swishy on topic Hoo U Gunna Call
- Thank you received: 4705
7 years 5 months ago #175709
Replied by Mrsmackpaul on topic Hoo U Gunna Call
blue under coat Swishy ?????
7 years 5 months ago #175712
Replied by Morris on topic Hoo U Gunna Call
Maybe Swishy needs a few sheets of that pre-dried paint we were talking about last year. It would have to be battleshit grey.
7 years 5 months ago #175717
by rex
Replied by rex on topic Hoo U Gunna Call
Swishy mate
Assume it closes to 2.50 metres Guessing it widens to around 3.50 that would increase the payload by 9 tonnes.
And the holes are very American.
Rex
Rex
7 years 5 months ago #175718
ReX
M80
2.7m - 3.5m wide
The 'VBus has dislocated u're memory
here twaz all about
www.hcvc.com.au/forum/truck_Chat/15264-h...-gunna-call?start=20
M80
2.7m - 3.5m wide
here twaz all about
7 years 5 months ago #175828
by rex
Swishy mate
Yes I remember the posts regarding the walking beam, with a question on the width of the pivot.
My remarks this time did not question the design in fact, it is in my opinion a very smart idea for work in a large City.
As opposed to a 3 X 4 trailer it will handle another 2 tonnes, with no more tare weight thanks to the holes.
The big advantage is the increase in stability when the wheels widen to 3.50 metres with a high centre of gravity load.
Nothing wrong with the grey matter about to start fitting out another two 700 Volvos, the first ones with the crawler gear, not sure exactly the ratio in low about 45 : 1 put that with 4 .8? axles 216 : 1 that should take some weight of the steer on a big hill.
Res
Res
7 years 5 months ago #175855
ReX
We have never had any problems with stability
we prefere a rigid type suspension az in walking beam or Brentwood spring & beam
No problem with most of the weight on one side
the 49 Freighter would/could/should widen/narro like thiz n
Clikity .......................................................... ClikClikClik
7 years 4 months ago #176664
ReX
We find an overall reduction of bout 90:1 can spin the wheels on lift off on steepish general garden variety hill with 18.5t on drives on bit u men or concrete roadway
we filld out a requisite order in triple n get a keg of BS Gray
7 years 4 months ago #176675
Swishy am I looking at this future hot rod above from the front end one day or the back end ?????
must be some flash steel you blokes are using as the chassis rails look smallish
mind you I have no idea at all so I most likely have this all ass about and back to front
Time to create page: 0.560 seconds
