Grunty Beddy - 250hp rig...how?
15 years 7 months ago - 15 years 7 months ago #11208 by Atki-vated
Work this one out.
This Bedford is powered by a Leyland 0400, yet this 'artic and trailer' rig developed nearly 250hp way back in '65, how did they do it?
Look hard at the pic, there are clues...
Last edit: 15 years 7 months ago by Atki-vated.
15 years 7 months ago - 15 years 7 months ago #11209 by GM Diesel
Ringfeder on the front and 250 hp KW on the front with a stiff bar :D
Powered trailer I reckon....no other reason to have a fuel tank on the trailer
Last edit: 15 years 7 months ago by GM Diesel.
15 years 7 months ago #11210 by atkipete
It must be a powered trailer, question is how did they control it ? A lot of Kiwi trucks had tow couplings up front for shunting trailers into a tight spot.
15 years 7 months ago #11211 by Atki-vated
Too easy for you guys, there's a Thames Trader Diesel mounted between the chassis rails of the trailer, with a twin disc torque converter and 2 speed auto.
In the cab was an extra instrument binnacle with rev counter, thottle toggle, start key etc. There were micro switches on the throttle and clutch to control the trailer engine speed.
Apparently the pluses were;
A tight turning circle because the trailer engine could push the rig. It was easy to back, just line the rig up and use the trailer engine to pull the rig backwards.
If the truck broke down the trailer could push you home.
The main drawback was trouble with the many solenoids because the trailer engine was close to the road, most of which were gravel, so dusty when dry and mucky when wet.
More powerful trucks pretty much spelled the end of the powered trailer concept...
15 years 7 months ago #11212 by GM Diesel
Howdy Bruce,
Powertrans have been operating powered trailers in the North of WA for a few years using a Cummins combination system.
Cummins and Allison auto in the third trailer hooked up electronically with the tug.
Cool to watch taking off with smoke coming out of the trailer exhaust...if you dont know the setup its a real "what tha...."
Detroit are now joining in.. www.mtudda.com.au/index.php?id=33&item=143#d
Basil :D
15 years 7 months ago #11213 by Atki-vated
Hi Basil,
There ya go, can't keep a good idea down!
I think the concept actually originated in Canada for powering logging trailers and the idea was picked by a visiting kiwi.
I reckon modern day electronics and fly by wire will make the concept much more practical these days than back in'65 :-?
14 years 4 months ago #11214 by Fuller-Vit
Pretty sure that trailer killed a driver when it failed to decellerate in a bend on a gravel road.
Transport North Canterbury was a very innovative company.
14 years 4 months ago #11215 by MACKFR8
I'm new and I know this is an old thread but, is there a second 400 motor in the rear trailer and if so, how is it controlled.
1974 1418LS 4x2 prime mover
1974 1418LS 4x2 rigid
1973 1418 4+2 prime mover
1973 1418 prime mover
1981W model Kenworth
36 ft Flat top bogey
Time to create page: 0.451 seconds
