Volvo F7 head
9 years 11 months ago #161158
by TonyD
Volvo F7 head was created by TonyD
Hi one & all
Volvo F7, engine TD70G
Does anyone know where I can get a cylinder head for this beast, without costing me more than the value of the truck itself? Best if close to Brisbane as freight is always a killer.
Any info appreciated with thanks.
Tony
Tony
- Thank you received: 34
9 years 11 months ago #161159
by mercskeepmeinajob
Replied by mercskeepmeinajob on topic Re: Volvo F7 head
Try Whites diesel sandgate for 2nd hand, Multispares may have new cores or your friendly Volvo dealer can sell you a head from VMR parts (Volvo recycling arm)
The following user(s) said Thank You: TonyD
9 years 4 months ago #167573
by TonyD
Replied by TonyD on topic Volvo F7 head
Thanks for the info Merc. VMR is pretty good but rarely has anything I need (probably trying to steer me to Volvo genuine new). I didn't try the others as I changed direction. See below.
It wasn't the head after all. It was a tiny hole in 1 cylinder liner. We DID look but, it is so small, that we could not see it. :huh:
:ohmy: If anyone is interested, if we removed the liners and checked it out more closely, we still could not have seen it. Only a pressure test could have proved it 'holey'. I made up a 'gizmo' and was able to pressure test each liner without removing it. The result was startling. Cyl 1 inlet valve has a small leak, cyl 6 exhaust valve - bigger leak. Note that valves were done as head recond recently. Cyl 4 liner has a big leak. We pulled it out but cannot see the pinhole.
Now need lots of $$$$$$$$$$$$$$$$$$$$$ for 6 piston / liner kits.
Thanks again everyone, Tony
Time to create page: 0.246 seconds
