- Thank you received: 17
engine manual for as160 truck
6 years 8 months ago #193180
by Indiana
engine manual for as160 truck was created by Indiana
Hi, I am chasing a workshop manual to help me rebuild the engine in a as 160. the engine number is abd2402797. Thanks in advance
6 years 8 months ago #193219
Replied by JOHN.K. on topic engine manual for as160 truck
What you need is the AS line supplement to the big AR/AL manual.......CTS-11-1A......is your motor a tilt valve?...if so later manuals for the 281 cover what you need to know.....There is one trick in the early motors,is the big end bolts need the heads aligned to clear the cam lobes in some motors.Easily done if you know about it.The very best of the early manuals to find is the big AB series one,all the ones between AL/AR and AB are supplements to the AR/AL,which contain a lot of useless info on the big motors Blue and Red Diamonds.
6 years 8 months ago #193255
by Indiana
Replied by Indiana on topic engine manual for as160 truck
I don't think the engine is a tilt valve. How do I tell
6 years 8 months ago - 6 years 8 months ago #193261
Tilt valve engines have.......tilted valves.....(ie not vertical).....different rockers,rocker cover,head,etc,and head gasket,pistons.And a bit more power.
Last edit: 6 years 8 months ago by JOHN.K..
Time to create page: 0.403 seconds
