help needed to find cylinder head gasket for a C180 Cummins motor supercharged
3 years 2 months ago #227914
by porschea
help needed to find cylinder head gasket for a C180 Cummins motor supercharged was created by porschea
hoping someone might be able to help me
looking for cylinder head gasket for a C180 Cummins motor supercharged .
have tried Cummins themselves but no longer make them. have tried copper gaskets in adelaide but they need the old one to make one up but at this stage have not pulled down motor as want to make sure i can get one for it as motor is 69 years old.
am in Adelaide south Australia
3 years 2 months ago - 3 years 2 months ago #227917
Replied by JOHN.K. on topic help needed to find cylinder head gasket for a C180 Cummins motor supercharged
Dont waste money with cutout copper gaskets.......they are worse than useless for diesels......Id say the gasket you want would be the C160 one ....ask FleetParts in Toowoomba.
Last edit: 3 years 2 months ago by JOHN.K..
3 years 2 months ago #227919
by V8Ian
Replied by V8Ian on topic help needed to find cylinder head gasket for a C180 Cummins motor supercharged
Try ACL, they used to custom make hard to source gaskets.
3 years 2 months ago #227923
by porschea
Replied by porschea on topic help needed to find cylinder head gasket for a C180 Cummins motor supercharged
thanks V8Ian
do you happen to have a number for them please
thanks in advance
thanks in advance
3 years 2 months ago - 3 years 2 months ago #227931
Replied by Lang on topic help needed to find cylinder head gasket for a C180 Cummins motor supercharged
Why not make your own?
www.hawleys.com.au/gasket-material-made-...ose-fibers-impregnat
But more practically this mob look to be your answer.
www.njgaskets.com.au/cutting/die-cutting/
Last edit: 3 years 2 months ago by Lang.
3 years 2 months ago #227932
by V8Ian
It would appear ACL don't do retail, try Repco or
www.enginemaster.com.au/ACL
3 years 2 months ago #227933
by porschea
Thanks V8 Ian
3 years 2 months ago #227934
by porschea
Thanks Lang
3 years 2 months ago #227937
I thought ACL had closed down.........wasnt that the reason given for stopping Falcon production?......I also went to an auction at Eagle Farm some years ago that was the ACL factory there........There was alot of original Warren and Brown machines there .
- Thank you received: 841
3 years 2 months ago - 3 years 2 months ago #227942
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic help needed to find cylinder head gasket for a C180 Cummins motor supercharged
The C series 160 / 175 / 180 use a steel plate gasget about 2mm thick .........the liners protrude from 004 / 006 thou above the block..........
The head squashes the plate onto the liners and the plate doesent virtually touch the block..............
The oil ways have a neoprane type seal that is part of the head gasget , while the water ways have fibre type square section rings that
are placed into the holes in the plate (head gasket).........
Waste of time making a copper type gasget.................
A couple of blokes in NSW (maybe still on this forum) ........Kirky or Chappo MAY be able to help..................
.....................Billy....................
Last edit: 3 years 2 months ago by BillyP.
Time to create page: 0.422 seconds
