5 Speed Maxitourque Shift Pattern Plarque
15 years 4 months ago #5900
by monty
5 Speed Maxitourque Shift Pattern Plarque was created by monty
Hi just wondering if any one has a 5 sp Maxitourque shift pattern plaque THINGY that some one is willing to part with? OR KNOW some one that has one, did they come out with one?
Thanks
-Monty
Thanks
-Monty
15 years 4 months ago #5901
Monty
GuddayM8
Sum years ago I needed one for a mack 6 speed
so I just printed one out n stuk in on the place where it should B
Ifn U need one designed
Let me no the size n I'll C wot develops
Printer friendly Pamflet
Replied by Swishy on topic Re: 5 Speed Maxitourque Shift Pattern Plarque
Monty
GuddayM8
15 years 4 months ago #5902
by monty
Replied by monty on topic Re: 5 Speed Maxitourque Shift Pattern Plarque
Hey Swish, your such a good bloke, with your learnen an worldly knowledge and advice, where would this fourum be with out you. !!!!!!
thanks for the offer,
I was thinking more on the lines of one that mack would make and stick on the inside of the cab wherever its ment to be stuck (any one). just like the one's you see on the inside of Old B models the little aluminum plate,
i know its a bit anal but i even if it is just a 5 speed, just want to recreate what was 39 years ago. thats the only thing missin from the inside.
i could do the same just scan, print and stick the copy of the thing, but it would not look the same. i should have a pamflet some where.
thanks Monty
thanks Monty
15 years 4 months ago #5903
Monty
GuddayM8
SME again
Thamx 4 them kind wordz
But
I no nutn
I C nutin
n
I hear nutn
Here U go
cgi.ebay.com/ebaymotors/5-speed-Mack-Tra...0160601477QQtcZphoto
If U bung up a pic of inside of Mack we can all guess where to stik the 5 speed shift decal
Could B on heater box cover just in front of Gear stix
ButEyeDoSt&2BCorrected
Monty
GuddayM8
SME again
But
I no nutn
I C nutin
n
I hear nutn
Here U go
15 years 4 months ago - 15 years 4 months ago #5904
by monty
cool thanks for that swish, i have been looking each day on ebay, because somebody said that they were on there, but came up trups, must me my dislexia or not readen right, but what ever,
ill take a pic or find one and post her up for ya.
thanks again, ill get me one.
-Monty
-Monty
Last edit: 15 years 4 months ago by monty.
15 years 4 months ago #5905
by HeyCharger
Ditto Monty. I'm sure one day we will be able to stump Swishy. I will keep working on it
That's exactly what I did until I got a real one.
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Replied by HeyCharger on topic Re: 5 Speed Maxitourque Shift Pattern Plarque
Proud owner of;
15 years 4 months ago #5906
by monty
15 years 4 months ago #5907
15 years 4 months ago #5908
Replied by Sarge on topic Re: 5 Speed Maxitourque Shift Pattern Plarque
Monty,
I was after something similar for my ACCO, I dont know if Inter had a sticky transfer or a fancy plate, in any case I have contacted one of those Trophy joints, they laser print from a computer onto aluminium or plastic or do transfer stickers, so my ACCO will have an aluminium patch rivited to the dash with a laser printed copy straight from the good book, all I needed was the picture. They do the rest. and bugger all cost.
Good Luck
Sarge :-X
Good Luck
Sarge :-X
15 years 4 months ago #5909
by monty
Cool, Thanks for that fellas, now ill be on the look out for one of those plates and be off to the trophy shop.
-Monty
-Monty
Time to create page: 0.521 seconds
