International AR-110 Ute
11 years 6 months ago #138649 by Swishy
Replied by Swishy on topic Re: International AR-110 Ute
Graham
Really Gr8 job U B do n
My suggestion from me armchair
me guess U already kno
release pressure from the body bolts by loosen n
get a long jack like an acrow prop etc
pack the foot of the jack on floor of tub @ front drivers side
n head of jack push @ problem area top of tub wiff suitable packing
n a gentle pressure push the problem cnr out
n redo bolts 2 desired tension n release jack
U may have to jack further to allow for the cnr to spring back
But guess n U kno all the above
me jist think n out loud
11 years 6 months ago #138650 by grahamjb
Thanks Swishy, I will borrow my mates porta power and sort out the tailgate fitment over the weekend.
The lesson for me in this build is to bolt everything together a number of times before painting. It is incredible how much movement you get when various bits and pieces are added and removed as you go through the process of re-building these old girls. In this case I did a final fit and then sat the body on the chassis and all was good....the trouble started after I bolted things down.....
11 years 6 months ago #138651 by grahamjb
My mate is holidaying somewhere so I can't borrow his porta power so I went to plan 2 as you can see in the photo below
[IMG
I removed the rear body to chassis spacers and pulled the body down to the chassis with the tailgate opening spread and the problem is now fixed
[IMG
Except the doors don't line up with the door strikers any more which is expected with the amount I pulled the rear down. I will fix this when I finish fitting my hidden mechanical remote door release cable to each door (in case the remote control door release fails)
11 years 6 months ago #138652 by AT4114
Replied by AT4114 on topic Re: International AR-110 Ute
Fantastic idea there grahamjb they say necessity is the mother of invention ;D ps it's looking very nice cheers Bryant
11 years 6 months ago #138653 by grahamjb
Yes Bryant, the old Holden twirly jack still comes in handy :)
This is the pull end of my manual remote door opening cable that I made from a camera shutter release cable and a pushbike brake cable
[IMG
And fitted inside the door
[IMG
11 years 6 months ago - 11 years 6 months ago #138654 by grahamjb
I decided that the fuel filter is exposed and might get damaged by debris thrown from the wheel so I made up a removable box to protect it.
[IMG
The fitted box made from scrap SS
[IMG
Last edit: 11 years 6 months ago by grahamjb.
11 years 6 months ago - 11 years 6 months ago #138655 by Bobsboy
EEK
Fuel line, filter, hoses, clamps, nuts, bolts, screws and boxes.
Exhaust pipe.
Not that I'm an cynical untrusting paranoid scaredy cat. . . (love your work)
but
An elegant solution to a simple problem?
Murphy's Law, the KISS principal and Occam's Razor?
woofa.
Move the Filter?
bwwik?
just saying,
-b
Mucking about on the edge
Last edit: 11 years 6 months ago by Bobsboy.
11 years 6 months ago #138656 by grahamjb
There is no practical spot where I can relocate the filter to Bob. This is because the fuel pump and sender unit are located at the front of the tank as you can see in the photo below. There is no issue with the exhaust pipe which is on the other side of the chassis rail.
[IMG
11 years 6 months ago #138657 by Bobsboy
Ah well,
Ya had to do something I suppose.
All them dangly out bits around the filter weren't a good look either.
The box looks a reasonable thing to me too then - now.
Lookin' good, soon vroom vroom?
-b
11 years 6 months ago #138658 by Swishy
Tiz OK BobzBuoy
ifn U dont want it in your drive way
me nose plenty th@ will
letz C sum pix of your master piece BB
Time to create page: 0.331 seconds
