Austin loadstar rear brakes part brake down
9 years 6 months ago #160226
by CameronS
Austin loadstar rear brakes part brake down was created by CameronS
sorry if there's been a post on this but I couldn't find anything, I'm looking for a brake down on the rear brakes as I can't figure out how to get them off. Sounds simple but this is mystifying me. Any help would be great cheers
9 years 6 months ago #160227
by Mairjimmy
Replied by Mairjimmy on topic Re: Austin loadstar rear brakes part brake down
Cobber I have no breakdown of the brake parts but can you explain what you can't figure out and how far you have progressed, have you removed the brake drum yet
Colin
Colin
9 years 6 months ago #160228
by bel
Replied by bel on topic Re: Austin loadstar rear brakes part brake down
If you are taking hydraulic cyl off the backing plate there is a threaded Rod that connects to bi sector on inside of backing plate
You will need a special tool to undo this rod
If you need more help ph 0427506552
9 years 6 months ago #160229
by CameronS
Replied by CameronS on topic Re: Austin loadstar rear brakes part brake down
Thanks guys, yes Im at the point of pulling the piston side off the backing plate but am stuck disconnecting the two, sounds great bel I'll be giving you a call over the next two days. It has been doing my head in.
9 years 6 months ago #160230
by CameronS
9 years 6 months ago #160231
by CameronS
9 years 6 months ago #160232
Replied by mammoth on topic Re: Austin loadstar rear brakes part brake down
Those wedge & roller expanders were common to lot of pommy trucks of the era. The piston is either pulled by the hand brake rod or pushed by hydraulic and either way pulls on the wedge. From memory a screw in the side holds the piston captive, and then you have to unscrew the piston off the wedge pull rod(which you can't see).
9 years 6 months ago #160233
by CameronS
Thanks bel for all that info today, cheers mammoth they are funny little units
Time to create page: 0.409 seconds
