- Thank you received: 49
Eaton no 4 - tension on inner bearing nut?
5 years 10 months ago - 5 years 10 months ago #194287
by ashmenz0
Eaton no 4 - tension on inner bearing nut? was created by ashmenz0
Hi folks
Have just had inner seal replaced on the hub and ready to put back on.
Not sure of what tension to put on the inner nut. Do I do up until tight then back off 1/4 turn?
Thanks in advance
Ash
Thanks in advance
Ash
Last edit: 5 years 10 months ago by ashmenz0.
5 years 10 months ago - 5 years 10 months ago #194290
by Oilman
Replied by Oilman on topic Eaton no 4 - tension on inner bearing nut?
No Sure about the Eaton. My rockwell is do up to 200Ft.lb to seat the bearing and seal and then back off a turn. Do up to 50ft.lb and then back off 1/4 turn. Do this while turning the hub.
Last edit: 5 years 10 months ago by Oilman.
5 years 10 months ago #194291
Replied by Swishy on topic Eaton no 4 - tension on inner bearing nut?
Ash man
gudday m8
we normally put the bearing in the hub then the seal make sure the axle housing where the seal sits
is smooth and with a leading edge for the seal slides on.... keep turning the hub as U do up the nut
we normally do m F tight then back off enuff to make it easy to turn 1/8 - 3/8 of turn back off sounds bout right
gudday m8
5 years 10 months ago #194293
by ashmenz0
Replied by ashmenz0 on topic Eaton no 4 - tension on inner bearing nut?
Thanks lads.
Appreciate the quick responses.
Beer o’clock now so she’ll have to wait till the morn.
Time to create page: 0.374 seconds
