- Thank you received: 10
Stuck wheel bearing
4 years 5 months ago #203651
by AaronS
Stuck wheel bearing was created by AaronS
Hi all
Redoing front brakes on Bessie (C1600) and the inner bearing is stuck on the axle stub. Now, before I went and got the grinder and chisel, I thought it would be worthwhile seeking advice from people with far more wisdom and experience in these matters than I do.
Does anyone have any tips?
Regards
Aaron
Regards
Aaron
4 years 5 months ago #203653
by dno
Limited Access Excavations.
Replied by dno on topic Stuck wheel bearing
Run a bead of weld around it, half way round or a bit more works most times. The heat expands the race, then light hammer an chisel while still hot.
4 years 5 months ago #203665
Replied by Morris on topic Stuck wheel bearing
I have had success on other vehicles using a normal three prong bearing puller but you need three hands or a mate to help because there is not much to grip on.
I will be spending tomorrow with the owner of a D1610 and a 190, and an owner of D1510, AB1810 and assorted C lines and D lines, so will ask them.
- Thank you received: 835
4 years 5 months ago #203667
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Stuck wheel bearing
Don't run a bead of weld all the way around , because that will shrink the bearing cone and you will
have to grind it off. …………
………………….Billy...…………….
4 years 5 months ago #203675
by jeffo
Replied by jeffo on topic Stuck wheel bearing
Bearing splitter to grab the bearing and some threaded rod.
4 years 5 months ago #203680
by AaronS
Replied by AaronS on topic Stuck wheel bearing
Thanks all
Tried the weld but my skills are rudimentary at best. Don’t have a puller or a mate either so it ended up being the dremel and chisel. Gotta love those dremel tools.
4 years 5 months ago #203682
I forgot about the bearing splitter. (they don't split the bearing but open up to fit behind the bearing, collar, or what ever else you need to remove) I bought mine new from a tool dealer at a swap meet for $15.00. About $40 in shops. I have only used it twice but when you need it, it is worth its weight in gold! I pulled against it with my three-legged bearing puller. I have had that for ages and bought it for very few dollars at a Trash and Treasure market. Like a stud remover and a few other fairly cheap tools, these are a must to make otherwise nearly impossible tasks easy and quick.
4 years 5 months ago #203695
I know you have solved your problem but I ran it past Inter owning mate and his first comment was "Front wheel bearings are in the hub." Woops, I, and I think other readers, automatically thought of bearing on axle housing. Silly us!
He then said "take the hub to someone who has a press and push it out. problem solved"
4 years 5 months ago #203698
Replied by cobbadog on topic Stuck wheel bearing
In the first post it states the inner bearing is stuck on the axle not in the hub.
4 years 5 months ago #203720
Replied by JOHN.K. on topic Stuck wheel bearing
The inner bearing cone stuck to the axle spindle was common on the IH army trucks had done no miles.......seems IH made the bearings a very tight fit on new trucks,so they didnt come loose for a lot of miles.......When youre used to worn out trucks with 1/16" clearance between the cone and the axle,its not expected.
Time to create page: 0.581 seconds
