- Thank you received: 2565
Brakes, brakes, brakes (C1600)
6 years 2 months ago #204256
Replied by JOHN.K. on topic Brakes, brakes, brakes (C1600)
It can get real hard when the starwheels get the serrations chopped off them.....dont use sharp edged screwdrivers ,round the edges.
6 years 2 months ago #204258
by 2strokesrule
Replied by 2strokesrule on topic Brakes, brakes, brakes (C1600)
AaronS, everyone here has bought up good points, speaking from experience when working for an IH dealer in the 70s and 80s If you are certain your wheel cylinders, hydrovac (booster) and master cylinder are all good as well as brake pipes and flexible hoses and the vacuum system is air tight you wont have any trouble getting good brakes you must get them adjusted correctly and we always used a power bleeder. That era helped develop my complete hatred for hydraulic braking systems air brakes are so much simpler and far better. good luck with the project they are a good truck. 2strokesrule.
- Thank you received: 49
6 years 2 months ago #204462
by wedgetail84
Replied by wedgetail84 on topic Brakes, brakes, brakes (C1600)
This is nice and relevant to me - trying to get my cd1820 ready to drive 300km to our new house on a permit. Been over the brakes and they work reasonably well (especially once adjusted) apart from one rear wheel - one cylinder is seized not allowing the shoes back in and the other is leaking. Where did you get your cylinders Aaron?
Have managed to get a master cylinder kit in the way (it’s weeping). Do people advise preventative maintenance on the hydrovac or if it’s working would I be better off not disturbing it?
6 years 2 months ago #204464
by AaronS
Replied by AaronS on topic Brakes, brakes, brakes (C1600)
I tried adjusting all mine on the weekend. Little improvement so will take off remaining wheels and see what is going on.
I got my rear cylinders from power brakes in SA. The front ones I got online from USA because power brakes didn’t have replacements.
6 years 2 months ago #204465
by wedgetail84
Ah yes I’ve heard of power brakes. If you don’t mind me asking, how much did you pay for the cylinders?
6 years 2 months ago #204467
by AaronS
About $50 each delivered.
6 years 2 months ago #204733
by AaronS
So I am still dicking around with these brakes. Trying to adjust the front I snapped the adjustment bolt (do not ask. I am not really that mechanically minded). So my question now is - can I replace the bolt or do I have to source and entire adjuster. Will pull it down tomorrow to see but any help appreciated.
Thanks
Aaron
Thanks
Aaron
6 years 2 months ago #204741
by AaronS
I pulled it down this arvo. It is a special bolt so I’ll have to weld it up. Seems that the cam on the bolt is simply pressed on. PITA but at least I know what I am in for.
6 years 2 months ago #204765
by AaronS
To everyone that said I just had to adjust my brakes properly.........have another two beers tonight. Brakes adjusted and they are great. Had to pull off two hubs and clean up two sets of adjusters and make repairs to one set of brakes (from my own doing). Thanks again for all the help.
Aaron
Aaron
6 years 1 month ago #205091
by Blake
Replied by Blake on topic Brakes, brakes, brakes (C1600)
Final post on this topic.
Thanks again for the assistance. Brakes passed brake check with flying colours. Mechanic even commented on how good they were. Unfortunately replacing all the weak points meant the next weakest point was them susceptible and he blew a brake line doing the test. All good though. She passed and once the brake line is replaced I know they are safe brakes which is the main thing.
The following user(s) said Thank You: werkhorse
Time to create page: 0.271 seconds
