- Thank you received: 19
Looking for info on our 1953 Morris Bus
4 years 3 months ago #205329
by 14B-Beaver
Replied by 14B-Beaver on topic Looking for info on our 1953 Morris Bus
The following user(s) said Thank You: Chrisall
4 years 3 months ago #205332
by Chrisall
Hi Morris, it has neither of those.
Replied by Chrisall on topic Looking for info on our 1953 Morris Bus
Morris wrote: Does it have an overdrive box at the back of the gearbox, or a two speed diff? Both of these are unlikely on a bus but you never can tell.
4 years 3 months ago #205333
by Chrisall
Yes, it is a bit of a mystery! The grille has been butchered at some stage, I guess to add aircon. Although the ID plate indicates 53 which would be an FV I think it's actually a 54 chassis cab which is an FE. I believe this is how the grille should look:
www.trucksplanet.com/catalog/model.php?id=1733
Pretty sure that the Morris has the horizontal grille whereas the Austin badged version of the same chassis has the vertical grille as shown in your pic.
14B-Beaver wrote:
Attached is the only Austin Bus Chassis available in 1953-1954.
I think yours is a later Model as it is fitted with webbed front hubs and the front grille resembles a Series 3 Austin. Probably around 1956.
Time to create page: 0.440 seconds
