For the “G” Cab Leylands, as they all basically look the same - the wheels are generally the easy quick way to ID them.
All “Terriers” sit on 6 bolt wheels as they are the lightest , mostly in 16 inch (stock , very common) – but can be 20 in (still 6 bolt, with 16 in brakes) - generally running a petrol V8 or a miserable tiny Perc diesel (247?) that was on old sold to Mazda in the mid 80’s. Air over hydraulic brakes , Turner 5 speed (or Allison 540 4 speed auto (I have a couple of Allison’s) and a single or optional Leyland 2 speed diff (not Eaton) – with power steering in only the later versions. A lot of small/short Leyland buses were based on Terrier Chassis, using 20’s , autos and P/S – particularly in SA.
All “Boxers” sit on 8 bolt rims – they are the most common version and they came in a few weight ranges from light to ‘bout 12 ton so they mix in with Air over hydraulic in the lights and full air brakes in the heavy’s – but they normally runs Leyland own 6-98 diesel six cyl engine, (sometimes a slightly bigger perc six (345 ?) - a non OD Turner 5 speed (or Allison 540 auto) and unless its the lightest (which will be single speed) – they basically have the same Eaton 2 speed diff as the Dodge - with power steering as they were mostly side by side competitors in the heavier ratings at the time.
The Reiver is a 10 bolt wheel Boxer – basically on steroids, using the 6-98 (turbo in later models) – often with a early Road ranger, and Eaton 2 speed. Some even got the Leyland “fixed head” engines, but they are a bit too heavy for what I want.
The Mastiff was the heavy – so mostly a Prime or something like a cement mixer in a chassis, 510 – 540 V8 Percs or similar, 5 speeds, Eaton splits, full air etc, etc,
Mostly the heavies are useless to me – as I have a few heavy Terriers, but I am building a big mobile home to tour the outback – so I want to go up to the next lever Boxer which is generally closest to the 3 Terriers I have – but I want the Boxers 20in brakes, Power steering and the split Eaton.
I have been eying off a few I.H. - Dodge 4x4 chassis with the thought of making the mobile home 4x4 with Dodge 4x4 gear as there are a few places I want to go that need 4x4 – so I will have a tag along , but it would be nice to take the whole rig there.
If it’s a 8 bolt – it’s the best bet. I am not concerned about the engine running / or trucks general condition – as I have a pile of spares – and a spare complete Leyland truck. Most 6-98’s either run or are dead (and a lot are dead nowadays), but I have Leyland’s about – not Dodges – so there is 100 little bits I can get off a Leyland, but a old 4x4 Acco or something I can cut up is cool too.
