- Thank you received: 1086
Gemmer steering boxes.
2 years 10 months ago #221393
Gemmer steering boxes. was created by asw120
A bloke near me has ordered a kit for Gemmer steering box from a Dodge 200 / 300.
We are wanting to know if you can just press the worm onto the shaft. We were planning to cut the old worm off (not all the way through and the split with a cold chisel).
Haven't thought about the yoked part, yet.
Thanks, Jarrod.
Thanks, Jarrod.
2 years 10 months ago #221401
Replied by mammoth on topic Gemmer steering boxes.
An attempt to press the old one off will tell you one way or the other. Heating won't help as the shaft will be warming up just as fast as the worm.
2 years 10 months ago #221406
Replied by JOHN.K. on topic Gemmer steering boxes.
if the worm comes as a separate part ,then the shaft must come out.......pressing the shaft out of the worm will be easy ,but how do you propose to press the lot back together?.....i wouldnt think pressing on the steering wheel end would be a good idea,and looks like you are going to need a special gripper for the shaft closer to the worm.......incidentally,the Ross boxes in Inters have the shaft friction welded onto the worm,and the two have been known to separate while driving.......I once had an AS 170 that had broken the steering box three times ...drivers then refused to drive it any more........the reason was the cab had shifted on its mounts because the rubbers were all disintegrated.
2 years 10 months ago #221408
Replied by cobbadog on topic Gemmer steering boxes.
If you are going to be having a go at it and once you have the new worm gear in your hand don't worry about trying to press the old one off, use an angle grinder and cut it length ways to release it. Even if you only cut 2/3 of the way through then talk to it with a chisel. That is of course it is removable.
2 years 10 months ago #221410
Replied by asw120 on topic Gemmer steering boxes.
Cobba, that was the plan. Not touching it until the parts are in hand. Only place he could find parts - Argentina. Hopefully in transit.
2 years 10 months ago #221414
WOW, hope there are no added packages in with the repair kit.
2 years 10 months ago #221429
Replied by Morris on topic Gemmer steering boxes.
Cobbadog You are a naughty boy! He said Argentina, not Columbia.
2 years 10 months ago #221441
They did take care of El Chappo but some of his officers jumped the border,,,,maybe.
