- Thank you received: 2500
Bedford cabs on Macks
2 years 8 months ago #223032
Bedford cabs on Macks was created by hayseed
Wasn't there a NR Mack around Wollongong with a Bedford Cab Fitted??
Maybe Roy Behn..??
Maybe Roy Behn..??
2 years 8 months ago #223036
Replied by Dave_64 on topic Bedford cabs on Macks
Seed, think your right, maybe had a cupla Spicer boxes in it, IF same one I saw, was parked in a yard at Yass for long time, R/H side of highway between Yass River bridge and where the old rail line crossed just before gasoline alley. Dave
2 years 8 months ago - 2 years 8 months ago #223037
by xspanrman
Replied by xspanrman on topic Bedford cabs on Macks
Peter Monaghan's 6-71 GM Bedford on NR chassis from Nth Wollongong.Wasn't there a NR Mack around Wollongong with a Bedford Cab Fitted??
Maybe Roy Behn..??
Last edit: 2 years 8 months ago by Gryphon. Reason: Fixed up quote and eply
2 years 8 months ago #223039
by xspanrman
Roy Behn's Bedford. Grant Stack photo.
2 years 8 months ago #223040
Replied by hayseed on topic Bedford cabs on Macks
Thanks xspannerman..
i was actual thinking of this Truck..
https://lh3.googleusercontent.com/proxy/0avpFIbJhMOKviILg62SAecsrXyTP_9Y6W_6RxAVZ_TKlUPRu-13dAF7jOupnCHOvtmeZFUnBXouPzZyKCQcxzuvfqS9rvSxDg
Maybe Peter Monaghan's
2 years 8 months ago #223048
by xspanrman
2 years 8 months ago #223049
by overnite
Replied by overnite on topic Bedford cabs on Macks
Never realised a Bedford cab could look so good.
2 years 8 months ago #223052
That Roy Behn's Bedford/Mack was credited to Grant Stack.
That would nearly have to be Frank Stacks son wouldn't it?
Frank drove for both Behn's and PCT amongst others.
Dave_64
Dave_64
The following user(s) said Thank You: xspanrman
- Thank you received: 835
2 years 8 months ago #223271
by BillyP
There was a story on Roy Behns Bedmacks here a few years ago...........
......,NR Mack chassis and rear end , 4x4 spicer box , 250 Cummins...........
I did an in frame overhaul on one when i worked at Cummins Lansvale....
The cab was fixed so ,half the work was outside , half inside..........
Yeah didnt make for easy access , but was still accomplished . .......
In all, not a bad unit for the time..........
..................Billy...................
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Bedford cabs on Macks
Time to create page: 0.602 seconds
