- Thank you received: 313
Old Atkinson Identification
- Inter-Action
2 years 5 months ago #227907
by Inter-Action
Replied by Inter-Action on topic Old Atkinson Identification
Regarding the Atkinson dating. The only info off the windscreen is "Triplex", Toughened, with an Asterix under the word toughened and the letter "F'.
Not much to go on. The owner has stripped the panels off the cab so not sure any photos will be of much use. The cab has been pressure cleaned so may be able to check the engine number.
Thanks for all the input. Dave.
2 years 5 months ago #227910
Replied by JOHN.K. on topic Old Atkinson Identification
There is a Gardner list online somewhere that gives number by month........I copied down all the Gardners I have ,which range from 1946 to 1964.
2 years 5 months ago - 2 years 5 months ago #227929
Replied by mammoth on topic Old Atkinson Identification
Look for a dot above T,R,E,X which gives the quarter of the year and look for a dot (or asterix) under one of the letters of "toughened" and this gives the year of the decade. No dot is 19x2.
The F letter I can't explain.
Is the radiator an old fashioned alloy one or the more modern style behind a grille?
Amongst the complications are that the code changed after 1969 and again in the 1980's. If your screens are tinted they are "Sundym" and use a different code again.
Check all the windows in case some are different.
Last edit: 2 years 5 months ago by mammoth.
- Inter-Action
2 years 5 months ago #227930
by Inter-Action
Thanks for the w/s info. I will try and have a look tomorrow . Dave
2 years 5 months ago #227945
Replied by hayseed on topic Old Atkinson Identification
2 years 5 months ago #227949
by Muttlee
Replied by Muttlee on topic Old Atkinson Identification
Hi, There is a fella on the FB group who has all the build records from Atkinson Preston UK, he got my record for me.
I posted this comment on the FB HCVC page so if you reply there l can tag him in. His name is Paul Allen.
- Inter-Action
2 years 5 months ago #227964
by Inter-Action
Thanks for that offer. Unfortunately i am not on Facebook. Got badly burnt a couple of years ago.
2 years 5 months ago #227969
Replied by Sarge on topic Old Atkinson Identification
I checked my old vic rego records, all atkinson chassis numbers are front left.... no further detail, the number will be preceded by 2 or 3 letters. .the letter difference seems to be axle configuration.
The following user(s) said Thank You: Inter-Action, PaulFH
2 years 5 months ago #227983
by Muttlee
When l got my chassis number tacked back to the build records it showed the single drive prime mover was sent out in a batch of x10 trucks without engine fitted.
Gardner engines were fitted locally in Australia.
Time to create page: 0.498 seconds
