Extended Tipper Trailer
3 years 7 months ago #235169 by V8Ian
Replied by V8Ian on topic Extended Tipper Trailer
What if the rear wheels castored on kingpins? They wouldn't have to turn far, to relieve scrubbing on a wide spread as such.
IIRC, Haulmark(?) were experimenting with such a set-up, fiftyish years ago, on a float.
3 years 7 months ago #235170 by Swishy
Replied by Swishy on topic Extended Tipper Trailer
Q:?could the trailer fromt axle B on a greasy plate turntable or ball race
me don't see no wheel marks from trailer
3 years 7 months ago - 3 years 7 months ago #235174 by Bluey60
Replied by Bluey60 on topic Extended Tipper Trailer
V8ian could be onto something milk tankers trialled tankers a few years ago that had the back axle of the tri steering on a kingpin arrangement worked well as far as stopping the tri chewing up the track where they turned sharp but the maintenance on them was horrendous
Cost way more than what they saved in tyre scrubbing
Bluey
Last edit: 3 years 7 months ago by Bluey60.
3 years 7 months ago #235175 by hayseed
Replied by hayseed on topic Extended Tipper Trailer
What if the rear wheels castored on kingpins? .
That's exactly how they Work Ian. Biggest issue I've found is you have to Have them perfectly straight before reversing. as whatever angle the rear wheels are once you start reversing is where they stay..
Bluey
Exactly Bluey.. It's cheaper to replace It with a Normal Axle than It Is to rebuild...!!
3 years 7 months ago #235177 by Zuffen
Replied by Zuffen on topic Extended Tipper Trailer
How come nobody commented on how good the Atkinson looks?
3 years 7 months ago #235179 by Mrsmackpaul
Replied by Mrsmackpaul on topic Extended Tipper Trailer
They did but not on this thread thats all
Told there was two of these trailers and the Atkinsons had 8V71s
Im trying to find out more information on these trailers anc trying to sort the grain from the chaff so to speak
3 years 7 months ago #235190 by Gryphon
Replied by Gryphon on topic Extended Tipper Trailer
Thread split from the Acco Atkinson thread found here, www.hcvc.com.au/forum/OldTruck/20072-acc...ters?start=10#229366
Terry
3 years 7 months ago #235192 by Mrsmackpaul
A little bit more thinking, yes to much time to think I know
So if this trailer has a steerable axle how come when I look at in a picture turning a corner and quite a sharp bend at that the trailer axle or axles aren't twisted at least a little bit ?
I'm not saying it isnt steerable but rather I just dont understand the added information provided by someone else
I also might add that I have asked for more detail from this person and so far I have heard nothing
3 years 7 months ago #235199 by V8Ian
It may have been reversed into that pose, Paul, in which case the axle would be locked straight.
3 years 7 months ago #235200 by Mrsmackpaul
I could of been but the tyre markes on the ground would to me suggest it was driven around forward for the photo
It doesn't really matter and always took the photo at face value until other people questioned it and then I started thinking about it
Time to create page: 0.313 seconds
