Another Bedford won't open
4 months 2 weeks ago #252006 by cobbadog
Can't open Another Bedford in the Restoration section but all others will open.
Any clues?
4 months 2 weeks ago #252008 by 180wannabe
You need to delete the last bit off the address in the address bar of that page, but i can't remember now what bit, or how much, to delete.
I will have a look n try and find it, and report back.
Brett.
4 months 2 weeks ago #252009 by 180wannabe
OK so if the address of the page you can't open ends in /unread  ,move your cursor up to the address bar and delete the /unread off the end.
I think that should work.
Brett.
4 months 2 weeks ago #252010 by cobbadog
Replied by cobbadog on topic Another Bedford won't open
Just tried with no luck removing unread.
tap on the Url it opened another box with the address but could not put the cursor  in either box to remove unread
4 months 2 weeks ago #252017 by 180wannabe
All i can suggest is you tap on the address bar once to highlight it in blue.  Then tap (or click) on it again, BUT not on the wording, make sure you are tapping/clicking on the empty space to the right of the wording.
Your cursor should end up at the end of the address.  Press the "backspace" (delete) key 7 times, and then press enter.
I apologise that i am a computer idiot and not able to explain this more correctly, but doing this works for me.
Brett.
4 months 2 weeks ago #252025 by cobbadog
Same problem on the tablet. Try to open, the page changes but some info on the left is missing.  Tap on the bar in the clear section after unread and the drop down box shows what's in my pic. Touch in the blank section there n it goes back to where we started.
  • Please Log in to join the conversation.
    4 months 2 weeks ago #252027 by Gryphon
    Replied by Gryphon on topic Another Bedford won't open
    Hi,
    click on this link to display the page and then navigate your way to latest post/page and then the issue should go away.
    www.hcvc.com.au/forum/restore/19595-another-bedford
    Terry
    4 months 2 weeks ago #252037 by cobbadog
    Got in. On my 2nd pic I tapped on  the pencil on the right in the search bar and that put the cursor in the correct place to back space.
    Gryphon thanks for your link and thanks for the other suggestions to try and get this non tech idiot to be able to rad the threaad
    4 months 2 weeks ago - 4 months 1 week ago #252048 by PDU
    Replied by PDU on topic Another Bedford won't open
    You're not alone, there are lots of us over 10 years of age who have difficulty with simple things, but what the hey . .
    10/10 for Gryphon once more, and not forgetting 180wannabe's efforts.
    P.S. I am still alive out here in the wilderness . . .
    Last edit: 4 months 1 week ago by PDU.
