Can not see a thread
3 weeks 5 days ago #254984
Can not see a thread was created by Lang
Everything is working fine except the thread "Another Bedford" All other threads and posts are OK.
There are 40 odd unread posts but all I get is an empty home.forum page
3 weeks 4 days ago #254990
Replied by cobbadog on topic Can not see a thread
All opening here Lang.
- Thank you received: 729
3 weeks 4 days ago #254992
Replied by 180wannabe on topic Can not see a thread
Only thing i can suggest is to click on "another bedford", and then have a look at the "address" across the top of your screen.
If it ends in "/unread", shift your cursor up to the end of the address in that address box, and use the backspace key to delete "/unread" from the end of the address.
Then i think press enter, and see if that helps?
Brett.
Brett.
3 weeks 4 days ago #254993
Replied by Lang on topic Can not see a thread
Who would have guessed anyone knew how to do that!
Worked just as you predicted.
Thankyou
Thankyou
3 weeks 4 days ago #254995
Glad it worked for you Lang, however i can't take any credit. Terry has mentioned that trick here on the forum a couple of times before, and because i am not very clever, i have to have a good memory! I have struck the same problem myself several times, and remembering that fix has always worked for me.
Brett.
Brett.
- Thank you received: 572
3 weeks 4 days ago #254997
by 77louie400
Replied by 77louie400 on topic Can not see a thread
Well, there you go, I thought that I must have upset someone and got myself bared from the thread. Thank you.
Time to create page: 0.417 seconds
