Coil Spring Modification
2 years 6 months ago #227141
Well Lang, the Travel would be reduced very close to 60%.. So My vote is for Stiffer..
Replied by hayseed on topic Coil Spring Modification
Would that make it stiffer or softer. I vote softer as it takes two coils out of play?
2 years 6 months ago #227142
by wouldyou
Replied by wouldyou on topic Coil Spring Modification
I agree with Hayseed, if all coils were treated similarly it would be close to rigid. It is half way there in the photo.
David.
David.
2 years 6 months ago #227144
by IHScout
Dennis
Replied by IHScout on topic Coil Spring Modification
I've seen a racing car being prepared for speedway track with all left hand turns by putting bolt in steel spacers on the coils in a similar manner to stiffen up the suspension on the left side of the car.
Dennis
2 years 6 months ago - 2 years 6 months ago #227145
Replied by Lang on topic Coil Spring Modification
Here is my thinking.
Every coil supports a certain amount of weight. This is spread evenly over every layer in the pack (unless they are tapered which these are not) By welding up the coils you are doing the same as cutting them off and putting a block on the bottom to make up the space with a shorter pack.
Each remaining coil now has to support more weight so they will bend and travel more before reaching their matching resistance = Softer ride.
If they reach full flat compression the whole coil pack is taken out of the game no matter how long they are but that is not the discussion.
Last edit: 2 years 6 months ago by Lang.
2 years 6 months ago #227151
Replied by cobbadog on topic Coil Spring Modification
To my way of thinking that the coils have been welded together it will be firmer because those coils are still there and not removed they still will have some action left in them and since they are no longer going to deflect that will make it stiffer.
2 years 6 months ago - 2 years 6 months ago #227157
The object of these is to keep the springs uncompressed so the wheels do not touch the mudguards in extreme situations. Also used to correct sagging springs in everything from sports cars to trucks.
- Thank you received: 1107
2 years 5 months ago #227166
by oliver1950
You can't have too many toys!
Replied by oliver1950 on topic Coil Spring Modification
2 years 5 months ago #227167
Oliver I reckon it just might work. It is only an after market airbag of the same design which is a common mod for those wanting better rear springs for towing etc. Only downside is longevity - I am sure a basketball would not take the rubbing a proper air bag would.
These Russians are pretty cool blokes.
The following user(s) said Thank You: cobbadog, oliver1950
Time to create page: 0.449 seconds
