Weighing vehicles simply
2 years 3 months ago - 2 years 3 months ago #230377
Weighing vehicles simply was created by Lang
What a great idea. A project for several of our team.
My homemade jack scale.
You will need to locate a hydraulic bottle jack that has a service port. This will be a screw out plug on the bottom of the jack. Unfortunately, jacks at Wal-Mart and Pep Boys (made in China) no longer seem to have the service port. So, you may need to search out yard sales or an older friends garage to find a bottle jack with the port. Remove the plug from this port and install a pressure gauge - I selected a liquid filled gauge that will measure up to 3,000#. To convert this to weight, measure the diameter of the jack cylinder (mine was 1.125 inches) and apply a little math to get the area of the cylinder (3.14 x radius squared). In my case 1.125 diameter /2=0.5625 radius x 0.5625 radius = 0.3164 x 3.14159 (pie) = 0.994 (my jack factor). Multiply the area by the pressure and you get weight.
The above information was originally found on an RV Camper forum and written by “Professor95”.
I changed the numbers to match my jack dimensions.
If you use a jack with a 1-1/8” cylinder you can use the direct read from the gauge and be accurate within 6 pounds per thousand. Gauge reading =1000# = 994# actual.
Gauge at Northern Tool was 12 bucks and the adapter fitting was about $6.59.
If you have a rubber plug and spring behind the service port metal screw remove the rubber and leave the spring. If the spring is so small in diameter that it slides into the new fitting you should cut a small hole in the rubber disk and use it as a spring stop. I think the spring holds pressure on a metal ball valve.
The front of my Baja weighs 706#
Dia Factor
1.125 0.994018711
1.5 1.767144375
2 3.14159
2.5 4.908734375
Dia Factor
1.125 0.994018711
1.5 1.767144375
2 3.14159
2.5 4.908734375
Last edit: 2 years 3 months ago by Lang.
The following user(s) said Thank You: 180wannabe, cobbadog, Inter-Action, Mrsmackpaul, PaulFH, oliver1950
2 years 3 months ago #230378
by Bluey60
Replied by Bluey60 on topic Weighing vehicles simply
Lang I hope your not going to work under there with no chocs under the back wheels
Bluey
Bluey
2 years 3 months ago - 2 years 3 months ago #230381
by Eddy
kinda got the impression he was just showing us how to weigh it ... ....
Replied by Eddy on topic Weighing vehicles simply
:roll:Lang I hope you're not going to work under there with no chocs under the back wheels
Bluey
Last edit: 2 years 3 months ago by Eddy.
- Thank you received: 4705
2 years 3 months ago #230383
Replied by Mrsmackpaul on topic Weighing vehicles simply
Thats a great idea, could also use this idea for the hydraulic press
2 years 3 months ago - 2 years 3 months ago #230386
Paul, I have an Old 100Ton Servex Press, & it has a Gauge mounted on it. & It's even calibrated to Tons. So I assume It's a factory Fit..
Bluey, I'm Pretty sure Lang has Just Copied & Pasted his entire post from another Forum.. BISTBC..
Replied by hayseed on topic Weighing vehicles simply
Last edit: 2 years 3 months ago by hayseed.
2 years 3 months ago #230387
by LN700
Replied by LN700 on topic Weighing vehicles simply
2 years 3 months ago #230388
Replied by Lang on topic Weighing vehicles simply
Bluey I think you know I am not into VW's. I always practice safety and if a dropped nut bounced into the centre of the vehicle I would get one of the grandkids to crawl in and get it.
If I don't think I can fool all of the people some of the time I try to put stolen information in italics. I don't bother with self-explanatory things like photo captions and screen shots.
I just looked and I have both a gauge and a suitable jack. I might see if I have enough suitable fittings and report back.
- Thank you received: 599
2 years 3 months ago #230390
Replied by 180wannabe on topic Weighing vehicles simply
Dad did something similar on a front end loader years ago, fitting a gauge into the lift hydraulics. He then picked up several different known weights to calibrate the gauge, and marked it with a texta. I think the loader arms always had to be at the same certain height off the ground when taking a reading though, to avoid false readings.
I have also seen the same idea on a semi tipper hoist. The driver put the hoist up about 3 or 4 inches while he loaded. I reckon his trailer had airbag suspension with a weight gauge, but the prime mover was on springs, and apparently the gauge plumbed into the hoist gave him a guide to avoid overloading.
2 years 3 months ago #230391
Now thats a clever idea, I can see this in my future
2 years 3 months ago #230392
Back in the days before Airbag truck suspension. I had this setup, & with a bit of practice, I could get the Weight over the Drive to within 100kgs of Legal every Time....
I have also seen the same idea on a semi tipper hoist. The driver put the hoist up about 3 or 4 inches while he loaded. but the prime mover was on springs, and apparently the gauge plumbed into the hoist gave him a guide to avoid overloading.
Time to create page: 0.702 seconds
