- Thank you received: 577
Homemade Tools
6 months 1 week ago #255105
by Bluey60
Homemade Tools was created by Bluey60
What do you do when your mates don’t have a forty seven mm deep socket and you google and find them for four hundred dollars plus,you shrug your shoulders and say bugger that and go to work
6 months 1 week ago #255106
by Bluey60
Replied by Bluey60 on topic Homemade Tools
The top is the hub off a Rodeo CV joint that I had replaced a couple of weeks before cut the shaft off drilled a 3/4 hole and filled it out square
- Thank you received: 772
6 months 1 week ago #255111
by 77louie400
Replied by 77louie400 on topic Homemade Tools
Bloody hell in the toolbox on the Ute ever socket up to 2inch, every socket up to 50mm, most Whitworth and a few bigger ones to fit various large cable gland nuts. I will just stop work and stay home a protect my sockets.
6 months 1 week ago - 6 months 1 week ago #255115
Replied by jon_d on topic Homemade Tools
Ahh, yes. Having to make a socket! Nice job.
My simple trick is to weld a nut onto the end of the 'hex flats'. And then use a socket on the nut.
Also, if that's a Kubota engine, I had to split that nut to get it off mine. (V1502) - split by drilling through one of the flanges.
Last edit: 6 months 1 week ago by jon_d.
6 months 1 week ago #255117
This could be an interesting thread..... show us your home made tool.
I had to remove the hubs of the bus rear axle and when replacing, set the preload on the bearings. Some bright British spark decided to bury the nut deep in the hub, then to key in some sort of triangle fashion.
This was my special job.
The following user(s) said Thank You: cobbadog, Bluey60, overlander, 77louie400, PaulFH, asw120, wee-allis
6 months 1 week ago #255121
Replied by cobbadog on topic Homemade Tools
john d, that has me stumped unless its for a mower used on ice for traction
Bluey, well done. I did a smaller scale socket the same way. I made a socket to fit the wind up/down legs on the caravan. Then welded a long shaft on that with a ground triangle shape to fit my battery drill. I dont wind them down hard enough to want to lift the van up so I use the torque setting at 18 and that is just right. Sometimes my hands go kaput with arthritus and find it hard to use the crank handle
Time to create page: 0.327 seconds
