- Thank you received: 423
Camshaft Dow Pin
9 months 3 days ago #255747
by Urchy87
Adventure before Dementia.
Camshaft Dow Pin was created by Urchy87
Hey all.
I’m currently working on a Holden 308 and have come across a hurdle. I need to remove the down pin from a carburetor version of a 308 cam and swap it with the current shorter one in and EFI cam. I’m wanting to run a mechanical fuel pump but the current dow pin is too short as it’s not required to be long for EFI motors.
Have any of you removed a Dow pin from a cam? It’s in there tight, not sure on applying heat directly on to the cam with a flame, worried about metal embrittlement. Have thought about trying to freeze the Dow pin using a butane can or something of the like.
Curious to hear your thoughts.
Thanks, Urchy87
Thanks, Urchy87
- Thank you received: 7600
9 months 3 days ago #255755
Replied by Mrsmackpaul on topic Camshaft Dow Pin
I assume that you have already tried just grabbing it with vice grips and butchering it out ?
9 months 3 days ago #255758
by wee-allis
Replied by wee-allis on topic Camshaft Dow Pin
Years back I had a customer with a 350 Chev which had sheered the dowel for the fuel pump cam. I couldn't get the stub out, so I just rotated the cam 90 deg, drilled and tapped a new hole in the cam boss and screwed a 5/16 high tensile bolt into it with lock-tite. Cut the bolt off to length and away it went.
Ran in a high-performance speed boat for several years.
This may work for you.
9 months 2 days ago #255778
by wee-allis
Dowel pins usually are very hard, as the bloke in Lang's video shows. As the fuel pump operating cam is just a tin can so to speak and it doesn't need to be timed it can be located in any position.
The boss on the end of the camshaft where to pump cam is, is also case hardened, as it forms part of the front cam bearing, but the centre section/face is not, so no problem to drill and tap. In fact, I did this repair in situe with hand tools, at night in the shed.
9 months 2 days ago - 9 months 2 days ago #255779
Replied by jon_d on topic Camshaft Dow Pin
Thanks Wee-Allis.
I was more wondering about the first video where the bloke made a pin and then drilled it. I presume it wasn't case hardened .
I imagine, "you'd" need to grind the top off a case hardened pin before trying to bore the centre and then fill with oil and punch it out.
And then, the wider the bore, the less psi is generated from the hammer. There must be an optimum bore size the lift the pin versus the compression PSI when the pin is hammered.
But thinking about it some more, how can "you" drill though the case hardening at the other end of the pin? You cant get to it and grind the hardening off.....
or am I missing something?
Last edit: 9 months 2 days ago by jon_d.
6 months 3 weeks ago #256744
by Urchy87
Replied by Urchy87 on topic Camshaft Dow Pin
Hey all.
Apologies, I had typed out a reply but must have got sidetracked and not actually submitted it.
Thanks for the tips. I ended up doing it completely different to the videos you posted Lang. For removal, I welded a bolt to it and used it as a puller, worked reasonably well and learnt a few things in the process for if I need to do it again
I started a YouTube channel a few months back for all the junk (mostly cars) I will be working on. I’ll post the video I uploaded on how I went about it. I’m no professional with tools, filming or engaging an audience, just a hack having a go but here is the link for what I did if you are interested or happen to find yourself needing to do it also. Cheers all for helping out once again.
HOLDEN 304 / 308 EFI CAM TO MECHANICAL FUEL PUMP CONVERSION. HX MONARO LE COUPE V8 ENGINE
6 months 3 weeks ago #256745
Replied by JOHN.K. on topic Camshaft Dow Pin
weld a thick washer onto the dowell with stainless rod ....mig will probably be OK too...........then pull it out ..........if its sheared or been mangled ,then drill with a solid carbide pyramid point .....a solid carbide die grinder may be OK ......when you have a hole in the dowell,fill this hole with weld .....the dowell will fall out.
The following user(s) said Thank You: 180wannabe, Urchy87
6 months 3 weeks ago #256746
I wonder if a brass airline fitting, with the olive that compresses onto the airline would grip tight enough on the dowl to pull the dowl out
Also pays to soak the rags for few minutes before using the for this type of thing, I have had some good unintended fires over the years
Burnt a rew acres once, woops
Time to create page: 0.344 seconds
