What is the best
17 years 8 months ago #2274 by
What is the best was created by
I'm about to repower my1936 Bedford so i'm asking all you experts what to put in the old girl and should i run her on , Gas - Petrol - Diesal i thouht i would ask the EXPERTS . Dave
17 years 8 months ago #2275 by atkipete
Replied by atkipete on topic Re: What is the best
If you want to keep it original then you got to find another Bedford donk,
If you cant find one and just want to get it back on the road, get the guts out of a Ford or Holden ute. A lot of work getting engine mounts, radiator hoses, tailshaft, gear lever etc to line up however. Diesel is only worth it if you are doing big miles and LPG will never look original.
Then you going to have to get an engineer to certify it all.
17 years 8 months ago #2276 by ray
Replied by ray on topic Re: What is the best
I'm not sure how original you want to make it look under the bonnet, but what about a Holden grey motor which may appear to have a similar appearance and at least parts are available and it should be fairly economical.
17 years 8 months ago - 17 years 8 months ago #2277 by Andy Wright
Replied by Andy Wright on topic Re: What is the best
A post from Barry who is logged in but still can't see the reply button:
Grey holden motor would be a good swap and you may even be lucky with the flywheel housing. There is of course another quality GM product you can use if you want to cruise in style. I can fix you up with a 3-53 detroit ! Barry
Last edit: 17 years 8 months ago by Andy Wright.
17 years 8 months ago #2278 by duncan_m
Replied by duncan_m on topic Re: What is the best
Sounds like you're building a hotrod.
Dunc.
17 years 8 months ago #2279 by
Replied by on topic Re: What is the best
Good one Duncan ;D ;D i deserved that one!! , the 3-53 detriot sounds fine but it wouldn't do not in a fine british machine thanks Barry.
The motor have to be pommey :D :D.Dave
17 years 8 months ago #2280 by GM Diesel
Replied by GM Diesel on topic Re: What is the best
A BMC diesel like out of a pommy taxi would do the trick Dave.
17 years 8 months ago #2281 by atkipete
Pommy engines sort of narrows your choice Dave, two suggestions are a P6 / R6 Perkins or a Rolls Royce Merlin. Vicroads might prefer the Perkins.
17 years 8 months ago - 17 years 8 months ago #2282 by bparo
Replied by bparo on topic Re: What is the best
Why not borrow that motor off the back of Warwick Bryce's Foden. That would get the Bedford moving!
Last edit: 17 years 8 months ago by bparo.
17 years 7 months ago #2283 by Andy Wright
Dunc.
;D. Classic.
Time to create page: 0.301 seconds
