Buzzer, where is that darn thing.
8 years 8 months ago #161001
by kind_cir
A win without a challenge
Buzzer, where is that darn thing. was created by kind_cir
Trying to locate the low air pressure warning buzzer because it don't buzz.
Truck is a 2001 Hino Fm 1j.
The warning light comes on but there is no sound.
Any info on how the system works or where the switch may be also ?
Thanks.
Thanks.
- Thank you received: 4707
8 years 8 months ago #161002
Replied by Mrsmackpaul on topic Re: Buzzer, where is that darn thing.
can you follow the wires back from the light to see were they go they must lead back to the switch I would think
8 years 8 months ago #161003
by kind_cir
Replied by kind_cir on topic Re: Buzzer, where is that darn thing.
I could but it would take a heck of a lot of pulling apart stuff to see where it all goes.
8 years 8 months ago - 8 years 8 months ago #161004
by atkipete
Replied by atkipete on topic Re: Buzzer, where is that darn thing.
The buzzer is possibly soldered onto the panel behind the instruments.
It should look something like this. demandware.edgesuite.net/aasr_prd/on/dem...ages/02730793_00.jpg
Last edit: 8 years 8 months ago by atkipete.
8 years 8 months ago #161005
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: Buzzer, where is that darn thing.
The switch would probably be on one of the tanks, or near the pedal valve. Following the airlines would be easier than trying to chase wires in a loom.
Buy a buzzer from Jaycar or Dick Smith and wire it in back to the switch.
8 years 8 months ago #161006
by dno
Limited Access Excavations.
Replied by dno on topic Re: Buzzer, where is that darn thing.
In my GH, the buzzer sounds like it's to the left of the clutch pedal possibly behind the dash below the cup holder. Bloody noisy thing, I haven't got close enough to see exactly see where it is.
Mine is a bit hit and miss, seems to work most times but not all the time.
8 years 8 months ago #161007
by kind_cir
I think I have tracked it down to uder the dash panel on the left behind the fuses. It's metal about the diameter of a 50 cent piece about an inch deep.
Now I just got to get in there and test it out. If I can find the switch that activates it, i'll test it too.
8 years 8 months ago #161008
It should be connected to the Low Air warning Light..
Replied by hayseed on topic Re: Buzzer, where is that darn thing.
8 years 8 months ago #161009
by kind_cir
Yes but the light works and the buzzer dosen't. The buzzer will only sound if the maxi's are released, but mine does not. There has to be a switch in the park brake circut somewhere.
8 years 8 months ago #161010
Are you talking about your Low Air warning Light? or your Park Brake Light?
Time to create page: 0.510 seconds
