- Thank you received: 49
Hino temp gauge problem
- wedgetail84
Hino emailed me the wiring diagram for the sender and gauge (combo meter) but it does't show any earths. Is any one able to decipher it or know where I'd find the earth?
- wedgetail84
Sum big beasties have factory set
to increase coolin wen AC iz on
dunno ifn u're lorry haz a variable speed fan or doodadd to increase cool n wen AC iz on
Jist guessin outside the square
otherz may kno bettr
:lol: :lol:
- wedgetail84
- wedgetail84
completely agree, it's finding them I'm struggling with. It's not short of a wire or two behind the dash and I need to find where to look...Swishy wrote: Crook Contact or and Earth
I f this is the case, when you have a reduced voltage supplying the gauge, the reading will be affected, ie , lower voltage with the same current running through the gauge changes the resistance, ie, more resistance = higher temp reading.
Hope this helps
Alistair
Your problem reminds me of almost every Austoft cane harvester and Powerhaul I have ever driven, as you'd have to turn off all your lights and air con to get an accurate fuel level reading.
- wedgetail84
Thanks - yeah this seems the theme. It's coming over today so I'm going to have at the fuse box and dash. First will check if they share fuses...Bitsa wrote: Sounds to me that you might have a crook fuze or connection supplying 24V to the AC or Heater Fans.
Hope this helps
Alistair
Thanks DD, good to know you've come across a similar problem. Now you mention lights I think someone might have mentioned the lights triggered the fault the other day!dieseldog wrote: I sent you a PM Wedgie.
Since the air con compressor and coolant temperature sensor are both earthed on the engine block, I would check the block to chassis earth strap.
