- Thank you received: 49
Spicer Syncro 7 drives more like a crashbox. Help!!
6 years 7 months ago #187010
by ashmenz0
Spicer Syncro 7 drives more like a crashbox. Help!! was created by ashmenz0
Hi
I have a Spicer "Synchro 7" in our bus coupled through a 14inch Spicer clutch to the Perkins.
My issue is mainly with gear changes. It seems that if i use the clutch "properly" the gears are a real bugger to find. If I just lean on the clutch i seem to be able to find the gears better. When I say lean on it, I mean just pushing through the freeplay and hardly feeling the pressure.
Is this a problem with the clutch, the gearbox or both??
Thanks in advance
Ash
Thanks in advance
Ash
- Thank you received: 4697
6 years 7 months ago #187011
Replied by Mrsmackpaul on topic Spicer Syncro 7 drives more like a crashbox. Help!!
does it have a clutch brake, if so it would explain what is happening as they only work when adjusted right when the pedal is fully pushed or in the last little bit of travel
6 years 7 months ago #187015
by ashmenz0
Replied by ashmenz0 on topic Spicer Syncro 7 drives more like a crashbox. Help!!
According to the book it has a Spicer solo adjustment free clutch. I believe this may have been replaced at some stage so I will need to check what it actually has now. Hopefully I will find something to identify what it is.
6 years 7 months ago #187020
by dieseldog
Replied by dieseldog on topic Spicer Syncro 7 drives more like a crashbox. Help!!
It might seem painfully obvious, but does the gearbox have oil in it and is it the right type?
6 years 7 months ago #187021
Replied by Swishy on topic Spicer Syncro 7 drives more like a crashbox. Help!!
Dose the clutch have the normal type linkage as in a truck?
OR
is it a cable or air operated from the front of the bus all the way to the rear
Jist think n out loud n out side the Square
ยง
OR
ยง
6 years 7 months ago #187025
by ashmenz0
Hi Dieseldog,
It does have oil in it, but I haven't changed it so I can't guarantee its the right stuff.
I will be doing a complete service/change all fluids so I have a start point.
Thanks
Ash
Thanks
Ash
6 years 7 months ago #187026
by ashmenz0
Hi Swishy
It has a cable from the front of the bus to the rear.
I haven't had the chance to check it over the whole length. I guess there are a number of areas over that length that could be an issue, starting at the stick.
My naivety just pointed me straight to the clutch.
Ash
Ash
Time to create page: 0.549 seconds
