- Thank you received: 17
2228 mercedes technical info
5 years 7 months ago #195932
by Indiana
2228 mercedes technical info was created by Indiana
Can anyone help with technical info for a 2228 Mercedes truck please. Particularly fitting a seal kit to the power steering box. I am having trouble with the power steering fluid being pushed out the resevoir
- Thank you received: 4707
5 years 7 months ago #195935
Replied by Mrsmackpaul on topic 2228 mercedes technical info
As in getting pushed out the filler cap ???
If this is the case, were's the extra oil c9ming from to over fill it ??
5 years 7 months ago #195937
by Indiana
Replied by Indiana on topic 2228 mercedes technical info
i don't think its overfilling but pressurising the reservoir
5 years 7 months ago #195938
Sounds like either air is getting forced in or the breather is blocked, maybe check for a leaking suction hose to the pump or a restriction in the reservoir causing the oil to cavitate ?
The following user(s) said Thank You: Indiana
Time to create page: 0.410 seconds
