Brake foot valve plumbing - please explain?
- theroadbossman
13 years 5 months ago #37035
by theroadbossman
Brake foot valve plumbing - please explain? was created by theroadbossman
Hi again knowledgable brethren, yep more questions on the old White... :
Been having a few intermittent problems with the foot valve for the brakes (brake lights staying on and the brakes felt like they were dragging a bit). So she now has a brand new single circuit E6 (I think he called it) foot valve and brake light switch. Fixed the brake lights staying on,, that don't happen anymore and neither does the brakes dragging, but now...
Driving it all of today, I notice that the brakes are extremely touchy. I have plenty of clearance between the pedal (the roller on the back of) and the plunger that actuates the valve. To best way to explain it, If I apply finger pressure to the brake pedal it will near stop the truck from walking pace. If I dab the pedal hard with my foot, the foot valve will "squawk" but will also stop OK. The drum temperatures all apppear to be similar - f&$kin hot front and backs, but that is Gold Coast traffic with 13.5 tonne on board. :
I am beginning to wonder if it is plumbed right. To make sure it went back together right, the whole thing was written on the white board before pulling apart, then the lines were tagged, and carefully put back into the respective holes after fitting the new valve.
The new valve looks identical to the old one, except NEW of course. It has 4 ports in the upper section and 4 ports in the lower section; all holes are the same diameter.
Does anyone have a sheet or other means of explaining how these things work and/or most importantly what line should go where? It may have been plumbed wrong for years as i have always had brake problems with this old chook. All rear axles are spring brakes while the front axle is air activated.
I reckon Swishy will have the appropriate sheet somewhere and most likely BigCam will have the summarised version
Anything that you guys can dig up will be a help; 2 different truck mobs gave me two completely different plumbing instructions today - and both of them different to the way it is actually done.
cheers and thanx in advance
Bretto
Bretto
13 years 5 months ago #37036
by Assessor
Replied by Assessor on topic Re: Brake foot valve plumbing - please explain?
Giday bretto i found this on the E6 ,i may help or confuse you worse! might get ya goin till swishy or big cam chime in mate!
Dual circuit brake valves utilize two separate supply and delivery circuits for service and secondary braking. The number one or primary circuit portion is mechanically operated through the action of the treadle/pedal and plunger. The number two or secondary circuit normally operates similar to a relay valve, with control air delivered from the number one primary circuit. In the emergency mode (failure of the primary supply), the secondary inlet valve is mechanically opened by a push through mechanical force from the driver's foot via the treadle/pedal, plunger and primary piston.
The E-4, E-6, E-10, E-12 and E-15 dual brake valves are floor mounted, treadle operated valves with two separate supply and delivery circuits.
- theroadbossman
13 years 5 months ago #37037
by theroadbossman
Replied by theroadbossman on topic Re: Brake foot valve plumbing - please explain?
Yep, you are right Adam, confused me more
That is the right valve though, so that is something, but where the pipes go, ummmmm, yer
Bretto
Bretto
13 years 5 months ago #37038
Replied by bigcam on topic Re: Brake foot valve plumbing - please explain?
Bretto, all the directions are marked on the valve.
Delivery to the front QR valve,
Delivery to the relay valve at the rear
Supply, air from the tank
And you may have another air line going from a "Supply" port to the air gauge.
- theroadbossman
13 years 5 months ago #37039
by theroadbossman
Hi Cam, the Eaton valve I got has absolutley no markings on it at all - hence the problem. Nothing in the box either. Only marking on the valve is a cast number "6" - that's it.
Of the 8 ports on the valve, 7 of them are used and 1 is plugged (unused).
Maybe i should take the time and do a drawing or something to show how this one is plumbed and then we could all see if it is right or not.
Bretto
Bretto
- theroadbossman
13 years 5 months ago #37040
by theroadbossman
Have drawn it, how do I put up a word document to show the drawing??
13 years 5 months ago #37041
by Chocs
Replied by Chocs on topic Re: Brake foot valve plumbing - please explain?
maybe it should be and e3 not an e6
i stand corrected, i think my tranny has e3 as do early kenworths.
they are not exactly the same, but i think have been interchanged in the past, i think the main difference is in the pedal end of the plunger?
if im wrong, so be it,
regards
chocs
regards
chocs
13 years 5 months ago #37042
by jimbo51
Replied by jimbo51 on topic Re: Brake foot valve plumbing - please explain?
E3 is the earlier single circuit valve.
13 years 5 months ago #37043
by jimbo51
At first glance the E3 and E6 look similar but the porting and operation is different.
These links to pdf's on the Bendix site provide a bit more info.
www.bendixvrc.com/itemDisplay.asp?documentID=2806
www.bendixvrc.com/itemDisplay.asp?documentID=2800
and a heap of other info in the Bendix document library
www.bendix.com/en/servicessupport/documentlibrary/doclib_1.jsp
- theroadbossman
13 years 5 months ago #37044
by theroadbossman
That confirms what came off was an E-6, and what went back on was also an E-6.
But the bendix document library, all 108 pages of documents, doesn't say in clear language what port is used for what purpose - in other words what hose from where goes where. Bugger. :-[
Acccording to Bendix, the E-6 valve is a dual circuit valve.
This might explain why when I took off one of the lines at the valve that goes to one of the brakes, all brakes still applied but air rushed out where I took the line off the valve. It apppears that if one circuit is interrupted, then the other circuit takes over and still feeds all brakes?
I'm still none the wiser - maybe I need to take some smart pills or something but the penny just hasn't dropped on this one just yet.
Bretto
Bretto
Time to create page: 0.489 seconds
