Picked up a Chamberlan Champion 236
12 years 1 month ago #117328 by q4016lanz
Well the canlander
12 years 1 month ago #117329 by Wilweld
On my Industrial MkII it's on top of the chassis rail just under the injector pump.
....Right about where the picture shows that bit of angle iron has been welded on....
Maybe they moved it on the MkIII ? Hopefully ?
Grant.
'79 F100- 302c 4spd&&'81 F350- Isuzu 6BB1&&Chamberlain Industrial MK11  (6G)
12 years 1 month ago #117330 by QLD Road Boss
G'day Fellas, While we are talking about Chambermaids, How do I make one stop a bit better I.E. 4280 and 4090 4x4 ??? I always found that the brake pedal was just for decoration....? ;D ;D :D :D 8-) What are the pit falls of these 2. Thanks Neil.
12 years 1 month ago #117331 by q4016lanz
One of my 236 brake works the other one hopfully just needs ajustment :)
12 years 1 month ago #117332 by elgindale
Hi Niel, I always thought the brakes were ok while going forward and were only non existant when backing up to the pig effluent dam with a linkage scooping device ,a neighbour also had his 4480 go backwards into a dam . Check you have brake fluid in the resevior.Both the 80 series and 90 series are good tractors but keep the universals between the gearboxes well greased as when these fail they knock off the hydrolic pump very hard to find now days or break the input shaft to the back end these are non existant as spare parts on the 90 series and cost about $3000 to have one made.All these Chamberlains are faily weak in the hydrolics I cannot lift a tonne with the front end loader on my 4490.The JD motors fitted to these like plenty of revs 2200 to 2500 more economical at that than 1600 and die quickly under 1600 rpm but at the high revs will pull as well as a modern tractor
12 years 1 month ago #117333 by Mrsmackpaul
Gudday Neil I have always found 80 series tractors to stop perfect for me going forwards or backwards the old C670 is a different story I think the same backend as 236 useless brakes had to plan ahead almost made it impossible to hookup 3 point linkage implements roll forward an inch back an inch hop on off bugger me made sure every thing was done before changing implement but they are a lot tougher than the 80 series just not as refined
12 years 1 month ago #117334 by q4016lanz
I'm puting linkage on my 236 with a external ram like my Q.Bulldog no easy with the big pto in the road :)
John
12 years 1 month ago #117335 by Mrsmackpaul
the linkage off a c670 wont fit? thought they would the 236 came out with linkage as well
12 years 1 month ago #117336 by q4016lanz
Yes the c670 linkage will fit i have fited one to my 6 354 Countyman but you have to cut a peice ont of the fuel tank to fit the hyd ram that why i was thinking of puting the ram veriticle of the draw bar :)
12 years 1 month ago #117337 by Nr Mack
Does anyone know what prefixes the countryman tractors have , as an example the super 70 has 70DA then a number, th eserial number book I have has just the number ie 1002..... can anyone help
Time to create page: 0.316 seconds
