- Thank you received: 407
4 years 8 months ago #202471
by Bluey60
Replied by Bluey60 on topic International A40 - 1 Superloader
Good to see progress I saw an a40 in a yard the other day and wondered weather you had made any progress
Don’t worry about the time frame I’ve got jobs here have been waiting longer than that and I haven’t even started kicking wheels yet
Bluey
Bluey
4 years 8 months ago #202473
Replied by cobbadog on topic International A40 - 1 Superloader
I don't think that Sarge was too worried about the project but I get the feeling there may have been an ultimation about fix it or throw it from the other half.
4 years 8 months ago #202476
Replied by Sarge on topic International A40 - 1 Superloader
YUP.....:S .... or else.
4 years 8 months ago #202488
Replied by bparo on topic International A40 - 1 Superloader
ultimatums are a good excuse to spend money quickly on bits you need, might need, or might just come in handy one day "After all you told me to fix it so I am just doing what you asked!" :blink: :woohoo: :evil:
(and yes it is the voice of experience - I hope you're faster at getting out of range than I am :whistle:
4 years 8 months ago #202499
Before I get too far ahead of myself, does anyone know anything about putting one of these F'ing heavy wheels back on and getting the wedges all lined up. How far do I push the wheel on before shoving the wedge/S in, etc.
I imagine I get the wheel roughly in place, slip both wedges into the spline and the spin the wheel to line up the holes.
That part seems logical, but how far on is the wheel and how far in are the wedges, I am concerned I could get the wedges up tight even though the wheel is only on a few inches and not on the full 8 or 10 inches.
..??????? Just asking. :S
4 years 8 months ago #202501
Replied by JOHN.K. on topic International A40 - 1 Superloader
yeah,theres a lot to ponder fixin tractors,which is why it doesnt pay to rush it...........I bin meanin to fix my slasher for about 20 years now.....people always say its dangerous havin the blades whirling round .........but I explain that it was more dangerous rusted nearly thru ,cause someone might have stood on it and gone thru......anyhoo,its easy to check the cat isnt hiding underneath before I start now,and it still cuts the grass when I get a council notice.
4 years 8 months ago #202505
by wouldyou
Replied by wouldyou on topic International A40 - 1 Superloader
Hello Sarge,
Oil the wedges so you can adjust the wheel while tightening the draw bolts, leave room between wheel and axle housing to relieve clamping of wedges during future removal!
David.
David.
4 years 8 months ago #202514
by Bluey60
If you get the wheel over the axle far enough so you can get the wedges started into the wheel and onto the spline line up the holes and start bolts in without making it firm then you should be able to slide the wheel and wedges on
There should be a bolt and big washer that fit on the end of the axle if you fit that bolt and washer and tighten it up that will locate the wedges in the right spot then tighten the bolts which will pull the wheel back onto the wedges as David said oil it up so everything is a little slippery
That should get the job done don’t know what to torque the bolts to but as an old mechanic told dad once when asked what tension on the head studs on the aw7 AS TIGHT AS BLOoODY HELL
If the wheel and wedges lock up before you get them right on you should be able to put a bolt in the threaded hole in the wedges to keep the wheel off the taper
Cheers Bluey
Cheers Bluey
The following user(s) said Thank You: wouldyou
4 years 8 months ago #202535
When I have to torque bolts up and dont have the right settings I use Google and enter that size bolt and it will tell what torque that size should be.
I have not seen this set up on anything before and I find it very interesting reading and hopefully learn something by it.
4 years 8 months ago #202537
Me too Cobbad. ..... thanks fellas for the advice..... will try and get the stud/bolt holes in the wheel tapped to suit a decent bolt before I do the exciting bits.
Time to create page: 0.480 seconds
