- Thank you received: 12
question about power assisted brakes
6 years 5 months ago #188727
by JMR
question about power assisted brakes was created by JMR
Hello all.
I have an old Cranvel crane, hydraulic disc in the front with 3 calipers per side operated off a big hand lever and rear chamberlain go faster brakes on a foot pedal.
the 2 master cylinders for the crane axle brakes are rusted out and trashed but calipers seem okay.
What would be my best bet for foot operated power brakes? fitting a vacuum pump alternator and using a vac assist master cylinder?
fitting a compressor and using an air/hydraulic setup?
Cheers.
Jacko.
Cheers.
Jacko.
- Thank you received: 4696
6 years 5 months ago #188730
Replied by Mrsmackpaul on topic question about power assisted brakes
Jack O I would say yes you are on the money for what I would do
I would also add a vacuum tank and a non return valve just encase you are idling around and need some brakes in hurray or maybe stall it and have some thing hanging of the hook and need brakes
6 years 5 months ago #188733
Replied by hayseed on topic question about power assisted brakes
How bad are your Cylinders?
A good brake place should be able to resleeve them I would Think...
6 years 5 months ago #188735
by JMR
Replied by JMR on topic question about power assisted brakes
Mrs
That was my original thought, think the vacuum system is a lot easier to make from scratch without trying to find a compressor to fit the 270 perk plus all the associated valves etc.
Hayseed
I was going to try and revive them but I figured if I am going to fix all the linkages etc on the big handbrake I might try and make it more user friendly and have a foot brake, its a mongrel thing to drive as it is without needing your hand for the brakes!
its got 3 calipers on each disc but is missing one and for the speed I drive it at I think 2 would be enough on each wheel.
Thanks fellas
Hayseed
Thanks fellas
6 years 5 months ago #188738
Replied by JOHN.K. on topic question about power assisted brakes
Spent many years fixing Cranvel,BHB,and Warman tractor mobiles.You must have front brakes,the crane has little traction at the back with anything like rated load,and will run away.The normal system on BHBs was air/maxi on the back,hyd disc front with one booster,and a footvalve.If you are handy to Brisbane,i can fix you up with what you need.No long distance repairs though.
6 years 5 months ago #188739
Just a thought,is this a triple ram Cranvel 'dinosaur" that drives back to front.
6 years 5 months ago #188740
by JMR
Hello John
I wish I was. but Mareeba is a long way from Brisbane! From what I've read i think id love to just see all your old stuff...
My friend has a Pacific with air brakes and maxis and it pulls up really well.
I am lucky that the hydraulic pump is not up to lifting a rated load of 6ton on the back hook and the pump stalls at about 2ton and the boom has a few twists so I don't think id push it.
would you advise against going the vacuum route?
Thanks
Jacko.
Thanks
Jacko.
6 years 5 months ago #188741
by JMR
nah just a 2 cylinder job, pivots just forward of the tractor diff with a linkage over the bonnet in tension. Dad reckons he can remember it at the mill when he was an apprentice.
6 years 5 months ago #188742
Compressed air is the go.A lot more compact,and bits are available.Used to be exempt from inspection if under 3 ton.CraneSafe has killed all the old tractors,my boss had a BHB they paid $58,000 for ,after cranesafe,sold for $5000 at auction.Had a $7000 repaired extension cylinder just prior.
