- Thank you received: 12
question about power assisted brakes
6 years 5 months ago #188745
by JMR
Replied by JMR on topic question about power assisted brakes
if you were going about this how would you mount the compressor? fabricate a bracket and run it off the fan belt?
Ive never played with any air brakes so not sure what im doing and any advise will be greatly appreciated
6 years 5 months ago #188747
Replied by JOHN.K. on topic question about power assisted brakes
Probably easiest.A lot of cranes had a compressor out the front,and needed a hole thru the radiator.Where is your hydraulic pump.Motor or on the back of the gearbox.You probably need a yard full of junk,mine is rapidly going for scrap,by request of the city council.
6 years 5 months ago #188749
by JMR
Pump runs off the crank under the radiator, its a tandem with some very "interesting" aftermarket plumbing...
What grounds do the council have to say you cant have "junk"?
Always a sad day when something goes to sims when it still has a use, but as Ive heard you say before, scrappies come when they say and don't muck you about...
Ive slowly amassed a grave yard of old gear down the back paddock that is always good for a look when I want to make something.
Time to create page: 0.402 seconds
