Gibb keys are a tapered fit into the hub of the flywheel so if you pull the flywheel you tighten it onto the key. I need to get both flywheels off to replace oil seals behind them on both sides and to get the the gears and pump on one side.
This engine is a slightly different design to most. The big end bearing is already off and sitting in the bucket of bits, but it is a separate item and is then bolted to the conrod using the 2 bolts for the bearing shells. You can add or subtract shims at the joint to raise or lower the compression. The other reason to get the crankshaft out is for cleaning out the crud and I am thinking of pressing out the liner as well to get the solid rust out of the water jackets and also to replace the sealing ring on the liner. Every little bit I can unbolt from the engine makes it easier to handle and for re-assembly further down the track.
Today I made up a tool to help flog the flywheel inwards after I get some heat into and around the hub of the flywheel. A piece of 3" water pipe with a handle attached and heavy bit of flat bar welded to the back end of it for the BFH can do it's job.
Started to heat up using my only source of heat a "B" size burner on a length of hose from the LPG bottle. I got comfy on an upturned 20ltr oil drum and started heating up. This is a slow process but then it started pissing down rain and guess where the water leak is, right above me. So I blew the whistle and went on with another job. Here is a pic of the good injector but needs a bloody good cleaning.
As for these injectors where the original one broke off is there suppose to be an "O" ring or something there or is the a copper washer to be fitted under the injector where it seats?
I have had a very kind offer of some oxy if required so time will tell.
