- Thank you received: 1712
3 years 11 months ago #208767
by wouldyou
Replied by wouldyou on topic McDonald Imperial Super-Diesel
Hello Cobbadog,
For what I imagine your engine is going to be doing in the future could this be doable? With a 100 mil angle grinder using a cut off wheel take away part of the unworn sides of the cam enabling a bit of flat strap curved to the original shape to be brazed in, filling any gaps with bronze as well.
Cheers, David.
Cheers, David.
3 years 11 months ago #208769
Replied by Morris on topic McDonald Imperial Super-Diesel
Smells like a Tooheys Old?
You are welcome to drink my share, mate.
3 years 11 months ago #208774
Cobba: I run 10%, but the current batch is a bit weaker and still working fine. I would definitely drain, scrub/blast and refill every day, or two.
3 years 11 months ago #208784
I should add some yeast and more sugar and let it brew peoperly.
When I do have a beer Tooheys Old is my first choice but the days of 10 - 12 schooners a night are long gone. So when I now have a beer the first doesnt touch the sides, 3 mouth fulls and the schooner has evapourated, 2nd one goes down somewhat slower.
Something else that happened today with the cam is I went to visit a small engineering company today and left it with him. He was super confident about welding it up with no issues so will see soon enough. I will linish it back to shape when its done. I do have a template shaped to the correct size and angles and is a neat fit onto the original shape of the cam. So although I have not done anything with the bore other than clean out the oiler hole I can now look at the piston and rings and see what needs attention there.
- Thank you received: 1166
3 years 11 months ago #208821
by Southbound
Replied by Southbound on topic McDonald Imperial Super-Diesel
3 years 11 months ago #208837
That one is no good, it looks empty.
3 years 11 months ago #208914
Just to keep on annoying you lot with my fun here is the next episode.
Started on the piston today. Cleaned it up a bit and found a unique way of removing the rings over all those ring glands by using the ring compressor back to front and it worked well. Piston is stamped with STD on top and has nothing to do with any diseases that get around. I stacked up the rings that came off the piston and roughly leveled up one end and found the other ends are all over the place.
3 years 11 months ago #208917
by Zuffen
Replied by Zuffen on topic McDonald Imperial Super-Diesel
Cobbba,
I've never seen a ring compressor used like that. I'll keep it in mind.
I noticed the rings get longer the lower down the set you go.
Could this be because the top of the piston is hotter than the bottom and hence needs more cold clearance?
Time to create page: 0.587 seconds
