Updated 28th July.
Welcome, Guest
TOPIC:
585 header 09 Nov 2020 16:49 #216182
  • cobbadog
  • Thank you received: 1624
Well that leaves you 2 options, low pressure to the injector or the nozzles are blocked.
Now I know next to bugga all about these diesel thingies but my big one lunger Lister diesel had fuel issues and after I sorted the rack on it I tried the pump and it did pump fuel up to the injector but I thought it was not enough so I kept stripping the pump and rack so many times. In the end I connected the injector while it was out of the head and tried it, success. I was amazed at how little amount of fuel that dribbled out of the line would pressurise enough to atomise the fuel so it may be as simple as a blocked nozzle/s
585 header 09 Nov 2020 17:34 #216185
  • JOHN.K.
  • Thank you received: 1126
The fuel pressure for injection is 2500-3000 psi...gemerally English stuff is in Atmospheres =15psi.......3000psi is 200 atmospheres.or 200atm...........Big proviso here is that the pump is correctly assembled..............fuel coming from the injector pipes,but no pressure/injection can only be air in the system...........there are no plastic/rubber seals anywhere in the high pressure fuel delivery,all metal to metal.
Last edit: by JOHN.K..
585 header 10 Nov 2020 11:00 #216221
  • mammoth
  • Thank you received: 537
Other possibility is that timing of the pump is out and is not injecting on the firing stroke. Unlikely I know but...
I have a Case 188 engine and after getting water in the injector pump I rebuilt it with a kit. Exact same problems of not firing and now won't even fire with a sniff.
585 header 10 Nov 2020 17:16 #216234
  • Mrsmackpaul
  • Mrsmackpaul's Avatar Topic Author
  • Thank you received: 2624
That would normally be a possibility but we can't even get the injectors to squirt
So I have a plan and will report back on my findings when I know some more
585 header 10 Nov 2020 18:19 #216237
  • JOHN.K.
I will guarantee that the problem is air in the pump.......when I have a pump apart I take great care that its properly bled before I install it on an engine.......Saves a lot of drama ...amd cranking.
585 header 10 Nov 2020 21:40 #216243
  • asw120
  • asw120's Avatar
  • Thank you received: 559
Is it possible to gravity bleed these overnight, as my Chinese tractor once did after I gave up trying to bleed it the normal way?
585 header 11 Nov 2020 05:23 #216249
  • Mrsmackpaul
asw120 wrote: Is it possible to gravity bleed these overnight, as my Chinese tractor once did after I gave up trying to bleed it the normal way?
No its not the fuel tank is bellow the motor
I have a plan and will see what eventuates from that
Will let you all know more when I know more
585 header 11 Nov 2020 08:49 #216258
  • Bluey60
  • Thank you received: 218
Electric pump is the first thing I’d try if it hasn’t gone for a while the lift pump could be sucking minute amounts of air if the diaphragm was a bit dried out
It will also give you constant pressure at the injector pump
Dunno worth a try imho
Cheers Bluey
585 header 11 Nov 2020 14:00 #216262
  • Sarge :-X
  • Sarge  :-X's Avatar
  • Thank you received: 428
Rip a V8 out of an old valiant, common drive motor for many around here. And imagine the hoon sound.
Sarge B)
585 header 15 Nov 2020 19:46 #216390
  • Mrsmackpaul
Well we did a temporary fix today as parts haven't turned up yet but this will keep us going
Time to create page: 0.369 seconds
