- Thank you received: 1107
Massey Harris 744D
- oliver1950
3 years 2 weeks ago - 3 years 2 weeks ago #220373
by oliver1950
You can't have too many toys!
Massey Harris 744D was created by oliver1950
I have a soft spot for Massey Harris tractors as my brother and I started wheat farming with a second hand $400 Massey Harris 745
About 10 years ago I saw a Massey Harris 744D row crop model for sale in Gayndah so I bought it and got it delivered on a back load.
It started easily and drove around quite well .As I don't have enough sheds to fit all my tractors it sat outside where I covered all openings to the weather with tin cans and periodically being turned over with the crank handle.Last week when I went to turn it over it was seized which surprised me as it was turning over when last checked in January.I dropped all the flood damage work ,towed it to the shed and removed the injectors and put a mixture of ATF and thinners down the hole left it for a few days still no luck. A freind came around and we tried again,he on the crank handble and I had a 500mm shifter on the crank nut. Still no movement so I decided to take the head off
I am impressed with the build of this motor but some things intrigued me as in the photo below there were a mixture of Whitworth and AF nuts and some metric on the injectors
To be continued as time permits
Last edit: 3 years 2 weeks ago by hayseed.
3 years 2 weeks ago #220394
Replied by JOHN.K. on topic Massey Harris 744D
The injector pump can also freeze up and stop the motor turning......using force might break something.
3 years 2 weeks ago #220402
Replied by mammoth on topic Massey Harris 744D
Mine turns over but believe that injector pump plungers are stuck so it won't start/run. Nice smooth motor, but provides a good illustration of 'torque rise' when going through a tough patch. ie there is none.
- oliver1950
3 years 2 weeks ago #220410
by oliver1950
Small bore and long stroke don't produce much torque
Replied by oliver1950 on topic Massey Harris 744D
My book on the Perkins P series motors says it has a bore of 3.5 in X stroke of 5 in 4.73 litres displacement 46 BHP at 1500 rpm.mammoth wrote: Mine turns over but believe that injector pump plungers are stuck so it won't start/run. Nice smooth motor, but provides a good illustration of 'torque rise' when going through a tough patch. ie there is none.
3 years 2 weeks ago - 3 years 2 weeks ago #220411
Replied by asw120 on topic Massey Harris 744D
I have a Farmall diesel here with a mixture of threads and spanner sizes on the fuel system which is CAV pump and Bosch injectors.
Hopefully nothing serious wrong with yours.
Last edit: 3 years 2 weeks ago by asw120.
The following user(s) said Thank You: cobbadog, oliver1950
- oliver1950
3 years 2 weeks ago #220412
by oliver1950
Next step take off the tappet cover.
The engine breather pipe goes from the tappet cover to this junction'it unscrewed easily but wouldn't come out as it was held in by carbon so I soaked it in thinners and it came out later
The tappet cover off, next step take off the tappets
- oliver1950
3 years 2 weeks ago #220413
by oliver1950
I tried taking off the water pump but no success, I found there is a piece missing from the fan pulley
The pushrods don't come out,I thought they would come out from below with the head off but they don't
I set up a chain block from the frontend loader bucket by chain and lifted off the head
And there is the culprit.No4 cylinder has water in it and has seized the motor
3 years 2 weeks ago #220415
All the P series Perks get excessive main bearing wear....on a P6 its usually the rear 3 mains will be badly worn........Fortunately ,the thin shell type bearings are still available,however early motors have thick bronze shells that need to be line bored,and are no longer available anyway.......the rods are the same....thin shell in late motors,thick in early ones........The P6 in my Coles crane seized because the fine mesh oil strainer in the sump choked with sludge......fortunately ,it seized on one rod ,and the mains were OK ,because they were thick shell.........I reground the rod journal ,and fitted one 020 bearing to a thin shell rod........and the motor went good for as long as I could climb into the old beast.....which I can no longer do.
- Thank you received: 4707
3 years 2 weeks ago #220419
Replied by Mrsmackpaul on topic Massey Harris 744D
Well thats the best outcome for a P6 Perkins
I reckon the are just a huge lump of junk, from my experience anyway
And especially when compared to the 6354
All stupidity aside from me, Im pretty sure you can get rings etc, or could get them 30 years ago
I was told that as the timing chain stretches the injector pump goes slowly out of time and this makes for hard starting and gutless operation, the two reasons I fell out of love with a P6
So probably disregard my ramblings
3 years 2 weeks ago #220424
Replied by cobbadog on topic Massey Harris 744D
I was shocked when I was told about the engine siezing up. As Oliver said it had all openings covered and with a tarp over the lot as well. This tractor to me is one that needs to be kept running and to be presented as it is now in its ''working clothese''. You can make out the stencilling on the tinware and just commands respect. Not sure if anything else has been found wrong but it would be intersting to know how water got inside #4, via head gasket?
I hope to hear it running again in the near future and maybe see it at the Rally this year.
Time to create page: 0.555 seconds
