Updated 28th July.
Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC:
Massey Harris 744D 09 Apr 2021 11:04 #220435
  • JOHN.K.
  • JOHN.K.'s Avatar
  • Thank you received: 1096
The P6 was a good motor in its day.(1936-1970s)....the bigger motor ,the R6 was a bit of a disaster ,and the S6 made in WW2 for boats was OK for the services who could maintain them properly.
The following user(s) said Thank You: Mrsmackpaul, oliver1950
Massey Harris 744D 09 Apr 2021 19:00 #220441
  • oliver1950
  • oliver1950's Avatar Topic Author
  • Thank you received: 467
With the head off I put the big shifter on the crank nut and it moved .So backward and forward a few times then round and round, I put the crank handle in and it spun freely
I had a good look at the head ,then the motor and decided to have the head serviced and to pull out the motor and strip it down .
This will be continued but now I have to get back to repairing flood damage
You can't have too many toys!
The following user(s) said Thank You: cobbadog, Lang, PaulFH
Massey Harris 744D 09 Apr 2021 19:59 #220443
  • asw120
  • asw120's Avatar
  • Thank you received: 551
Great news!
I wonder if it was just breathing through an open valve? I have a Stude straight 8 here that breathed through a loose cork in a spark plug hole - for about 50 years! Under cover the whole time, but the piston is corroded away right down to the rod. (and being aluminium, has eaten the bore, too. :( )
The following user(s) said Thank You: cobbadog, oliver1950
Massey Harris 744D 10 Apr 2021 08:33 #220448
  • mammoth
  • mammoth's Avatar
  • Thank you received: 486
Phew, lucky escape from a frozen motor
  • Page:
  • 1
  • 2
Time to create page: 0.414 seconds
