- Thank you received: 6328
International 554/564 Tractor
2 years 7 months ago #237087
Replied by Mrsmackpaul on topic International 554/564 Tractor
I have heard of the petrol soaked rag over the inlet manifold of a diesel
Always worried about the rag getting sucked in and creating more problems
I had the air cleaner duckbill off the D7 once, old 3T so only revs at 850 - 900 RPM at full throttle
It was quite scary to see that something so slow reving but big capacity could draw that much air at idle
It was a huge volume of air
Sorry off topic
Sorry off topic
2 years 7 months ago #237110
Replied by Sarge on topic International 554/564 Tractor
I had an expert machinery fella demonstrate the petrol tag on several old bangers, but his win rate was only about 50%. My old inter only needed a short sniff, and maybe about 3 or 4 seconds later she was purring. Another old time fix I was told of was borax. Take the inlet manifold off, get her ticking over and sprinkle the borax into the intake, it will freshen or deg laze the bore free the rings improve compression. In turn improve starting.
As you have found just cranking won't start her unless well warmed.
2 years 7 months ago #237130
by Tacho
Replied by Tacho on topic International 554/564 Tractor
Sarge, I remember an old trick to deglaze cylinders was to sprinkle Bon Ami (don't know if it still survives) into the air intake with the motor running. Lang, I have several J I Case collector tractors from the 60's and early 70's with the Lanova indirect injection system and the heat gun works.
2 years 7 months ago #237133
by wee-allis
Replied by wee-allis on topic International 554/564 Tractor
Saw the Bon Ami trick used on a Falcon at Bathurst years ago, around the Moffat years. Flagged off for smoke, into the pits, Bon Ami down the intake, instant de-glaze and back out onto the track. All good, at least for the day.
2 years 7 months ago #237149
Replied by cobbadog on topic International 554/564 Tractor
Not sure if Bon Ami is still available cause shopping is Dee's department not mine. But there are similar products and if I'm going to be arm pit deep in grease n shit I use it at clean me up stage to remove the bulk if not most of the crap off me.
2 years 7 months ago #237150
Replied by asw120 on topic International 554/564 Tractor
I was told of the "Jif hone" by a mate who said it was successful on a glazed up early Patrol.
2 years 7 months ago #237151
Replied by Lang on topic International 554/564 Tractor
Bon Ami (French for Good Friend) is still alive and well.
www.bonami.com/
www.bonami.com/
2 years 7 months ago #237159
Never knew they had battery heat guns, I would have thought that it would drain the battery very quickly - but if it did not start in that time it was not going to start anyhow.
If the Landcruiser gloplugs don't work I will look at it. Unfortunately all my battery stuff is Hitachi and I don't want to start down the slippery multi hundred dollar slope of changing my breed of tools. Maybe Hitachi (they call them something else now) has a heat gun.
Thanks for the info.
